Anti Freeze under valley pan
Old May 24, 2010 | 02:43 AM
Wasted's Avatar
Today when I finally found time to work on the SX I pulled the intake off and under the valley pan I found a little bit of anti freeze. The car wasn't smoking so I dont think its the head gaskets. I havn't drained the oil yet to check if any is in the pan. But where do you guys think this came from?
DSC00887.jpg?t=1274693905 As you can see there wasn't to much antifreeze under there. Could it have been from the intake manifold leaking?
Old May 24, 2010 | 03:11 AM
Mongoose's Avatar
My vote is either a leaky valley pan gasket, allowing the coolant to seep between the head and intake at one of the water jackets.... OR... when you removed the intake there was a residual amount of coolant still in the water jacket of the intake or head, and it dribbled into the valley when you removed the intake.
Looking at what comes out of your oil pan and more information on any other symptoms will help determine a cause. Plus you could look at the valley pan gasket to see if you see any stains or other marks that look like it could have been a path for the coolant to make it into the block.
Old May 24, 2010 | 04:46 AM
geckonz08's Avatar
x 2 on that option ^^^^. the oil and antifreeze seem to be in separate pools
Old May 24, 2010 | 05:09 AM
Destructor's Avatar
Residual coolant, if the oil looks fine don't worry about it, Both times I removed my manifold a small amount of antifreeze went into the valley.
Old May 24, 2010 | 06:55 AM
Ding, ding, ding.
We have a winner. If this had been a real leak, it would be milky white, not Mountain Dew green.
67townsedan
May 8, 2014 08:55 AM
edzolz
Feb 26, 2013 11:05 AM
HouTXCutlass
May 17, 2010 08:02 AM
mcutlass1969
Oct 25, 2007 05:00 AM
mcutlass1969
Jul 12, 2007 04:55 AM
