Adequate Radiator for a mild BB / 71
Old Feb 13, 2018 | 05:05 AM
Tiha's Avatar
I´m in search for a new Radiator in BB in a 71 Cutlass for HOT SUMMER Days.
The car has stock a 350 with a 2 Row. without shroud but Flex Fan.
What do guys think:
http://www.rockauto.com/en/catalog/o...,radiator,2172
think is a good idea to install shroud
https://www.rockauto.com/en/moreinfo...7528&jsn=10710
Le me know
Old Feb 13, 2018 | 05:45 AM
Lose the flex fan. Get a factory style six or seven blade clutch fan.
Old Feb 13, 2018 | 05:57 AM
Tiha's Avatar
okay and the Radiator ?
Old Feb 13, 2018 | 06:00 AM
I'm not a fan of radiators with plastic end tanks. The Spectra 351 is a drop in for your car. Personally I'd pick a four row to ensure no problems in the future but then you'd need to change the bottom brackets and top plate to fit the wider end tanks. Use a stock shroud.
Old Feb 13, 2018 | 06:26 AM
Tiha's Avatar
The The Spectra 351 seems to be 2 row which is now in the car.
You talk about this parts correct?
https://www.ebay.de/itm/68-69-70-71-...53.m1438.l2649
these brackets are for welding ????
Old Feb 13, 2018 | 06:37 AM
Sorry, I thought it was a three row. Three is the minimum I'd go with.
Yes, and yes, they are spot welded to the core support. You can also do the half-fast "hammer them flat" to make the old ones work, but it looks like crap if you care. Of course, you also need the top plate or at least the brackets for the top plate. This assumes you want to run a four row core.
Old Feb 13, 2018 | 06:51 AM
Tiha's Avatar
the stock core support (now with 2 row radiator) will also fit a 3 row but not a 4 row ?
Old Feb 13, 2018 | 06:56 AM
Yes
Tiha
Jun 6, 2017 11:44 AM
1964F85
Feb 12, 2010 07:14 PM
A72CUTLAS
Jul 27, 2009 08:32 PM
Rocketman
Nov 22, 2004 01:59 PM
