.921 lifters
Nobody is going to want to touch this question, cause that is when the flaming will begin. You have to use new lifters on a cam swap, what kind of garbage are you putting together, etc., etc.
What I will say is that when I was broke, and had to get my car going again, I took a used scotchbrite disk to the bottoms of a used set of lifters (just to remove the mating pattern), then ran the lifter in a figure 8 pattern on some emery cloth. Great pattern, and the cam was fine for another 40k before I sold the car (the valve springs had 95# on the seat, and like 240# open).
The next owner built a 455, and upon removal of the old cam and very old lifters found NO wear.
The cam mated just fine with those units.
That was almost 25 years ago.
I do not recommend doing that for your engine!
Nowadays, with all of the oil issues, I say get new lifters.
If you can afford to do the rest, get the lifters.
JMO,
Jim
JMO,
Jim
thanks guys.Not so short o money as 'just another thing I have to import" .I can tell you there are none here .I have seen a set of .842 and their brand was 'republic '.That name didn`t ring a bell .wrong size so wasn`t tempted .
Just means I will get a new set sent over at some point .Resurface existing and keep em for spares
cheers for that
mike
cheers for that
mike
