770 or 870 CFM Carb
770 or 870 CFM Carb
As I am now finishing my 455 build, I am looking into carbs, I want to go with the Holley Aluminum Street Avenger but I am not sure if I should go with a 770 or 870
The specs are here:
455 .30 Over with KB Positions
Edelbrock RPM Heads
Edelbrock Performer Intake
CompCams Xtreme Energy Cam Shaft (Don't have the grind on me, but its a aggressive street/strip cam)
The specs are here:
Edelbrock RPM Heads
The specs are here:
455 .30 Over with KB Positions Which one?
Edelbrock RPM Heads Stock? Ported?
The specs are here:
Ok so hear we go:
Heads: Stock with a Gasket Match
Pistons - KB icon Forged .30 Over (Running 10:1 Compression)
Cam:
Either the CompCams XE274H or XE284H
Specs of Cams as follows:
XE274H 1800-6000RPM
Peak HP - 447.7HP @ 5000RPM
Avg HP - 120.7HP
Peak Tourque - 561FTlbs @ 2500RPM
Ave Tourque - 185FTlbs
Lift - 0.520" Intake - 0.523" Exh
Duration at 0.050" - 230* Intake - 236* Exh
XE284H 2300-6500RPM
Peak HP - 460HP @ 5000RPM
Avg HP - 121.9HP
Peak Tourque - 540FTlbs @ 2500RPM
Ave Tourque - 182FTlbs
Lift - 0.541" Intake - 0.544" Exh
Duration at 0.050" - 240* Intake - 246* Exh
Which cam would you use, with which carb?
Thanks,
Jim
Cam:
XE274H 1800-6000RPM
Avg HP - 120.7HP
XE284H 2300-6500RPM
Avg HP - 121.9HP
Thanks,
Jim
I had the 274H XE cam in my 69' cutlass with 3.73 rear/2400 stall converter, and pretty much the same engine as you except i had ported/polished C heads. I ran the 770 street avenger on mine, was more than enough carb in my opinion, would smoke the tires from 1st all the way through 3rd
. The 870 cfm may be ok for the larger cam
Those average hp/tq numbers are awfully low.My dyno sheet had avg. tq of 523 ft/lb from 2500 to i think 5700. I'd have to look but I know that was avg tq. and peak tq was 540. Was that from an actual dyno sheet?
. The 870 cfm may be ok for the larger camBut seeing as how you have the Edelbrock heads why not use them and get a cam with duration more like the first but more lift like the second.
I could grind you something like a 232/240 at .050 with .568 lift on both, those heads will take .575 with the stock springs. I did something similar for my buddy's 455 Olds in a 79 T/A, ran sweet.
Jmo.
Those were the numberS from CompCams CamQuest I knew they seemed low
ziff396
Aug 11, 2009 05:34 PM
