'76 98 compression
Old Aug 25, 2007 | 06:53 AM
lebesset's Avatar
'76 98 compression
my buddy has this car which he bought new in canada , shipped to europe when he moved back
he used it for a while , then stored ; started it up regularly for a while , then lost the keys 10 years ago so it stood in the barn
well , we are both now retired and decided to do a restore ; after some preliminary work , new lock /oil/ battery / wiring that the mice ate etc , she started up ran rough for a while , compression test , a little low except for one cylinder ...zero!!!!
clearly it hasn't dropped a valve so must be rings or similar
short of stripping , any bright ideas?
tia
Old Aug 25, 2007 | 09:32 AM
442Harv's Avatar
Ring problem would not cause O compression. Being it sat so long, I would say you have a valve stuck open, or broken valve spring.Take the valve cover off and see if the rockers are moving. Do you have a cylinder leak down tester? That would help tell.
Old Aug 26, 2007 | 03:14 AM
lebesset's Avatar
thanks harv .....have taken the cover off and looked at the springs / valves and they looked correct to me
HOWEVER .. in view of your observation that rings wouldn't cause zero compression will have another look ....I did try the traditional tap with a hammer but maybe I was a bit cautious
anyone heard of mice eating pistons ?
Old Aug 26, 2007 | 03:25 AM
lebesset's Avatar
oh, and no leak down tester ....but easy to make an adaptor from an old spark plug and stick the airline on it ....should find a leak of this size !!!! thanks for that also
greenslade
Mar 29, 2011 03:56 PM
bobsrats
Apr 2, 2009 07:36 AM
Escalus2k4
Jan 15, 2008 08:29 PM
GoldOlds
Jun 10, 2007 01:26 PM
