73 455 edelbrock 1407 750 carb throttle issue
Old Sep 13, 2021 | 05:55 AM
KCastl03's Avatar
My throttle return spring has to be pulled very far out and tight for the car to idle at a low RPM and now it’s stretching my spring out as a result and starting to idle higher. Any suggestions as to what the problem could be and best bet for fixing it? Thanks for any help.
Old Sep 13, 2021 | 05:57 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
How old is the carb? It could be wear in the primary throttle shafts.
Old Sep 13, 2021 | 07:21 AM
gs72's Avatar
72Cutlass S
Disconnect the throttle cable and see if the problem goes away. If it does your cable is either too short or you need to somehow adjust the cable bracket for more freeplay in the cable with the throttle closed.
Old Sep 13, 2021 | 09:48 AM
KCastl03's Avatar
not very old. Previous owner barely used it and looked clean when I picked it up.
KCastl03's Avatar
Sounds good thanks for the info.
Old Sep 14, 2021 | 02:03 PM
RetroRanger's Avatar
72 Olds CS
A picture can help too.
i know the ebrock uses a different type of fastener cable to the carb VS a qjet.
Old Sep 15, 2021 | 08:11 AM
4R5's Avatar
4R5
I had a similar problem with a Holley on a 327 Chevy, Like you I initially put a mondo return spring but it was a pain in my leg to drive, literally. Its been a long long time but if I remember, the throttle linkage was slightly binding on the intake. What I would suggest is with the engine off, remove the return spring(s) and throttle cable, and the kickdown cable if there is one, and slowly open and shut the throttle, feeling for any binding. Barring none, then put on the cable and have a helper press on the accelerator pedal while you have your hand on the linkage feeling for any binding.
H8D-67
Oct 16, 2017 06:16 PM
76olds
Oct 2, 2017 03:05 PM
Kanesdaddy
Jul 8, 2014 11:04 AM
dingusboy
Sep 6, 2012 08:21 PM
W30post
Nov 30, 2007 02:46 AM
