72 W-30 455 Anything unique?
A little off from the OP but I was told all the Vista Cruisers with a BBO had the big valves. I would have no idea because i never had one but had always wondered if he was right. Joe, Would the 70 or 71 Vista's have Big valve heads?
Complete #'s matching 72 Olds Cutlass W-30 455 eng & trans 39k org mi
Yeah, the VIN derivatives on the engine and trans can match. Is this an OW trans? If yes, then maybe it's a real W-30 motor. If not, it clearly isn't.
More importantly, the W-30 intake and carb are long gone. The trans has been off, and possibly apart, since it has a "2800 stahl" converter. I guess that's better than a 2800 RPM STALL speed converter.
Original notched valve covers are gone. Original distributor is gone. Original W/Z manifolds are gone. What's left that makes it a "W-30" motor?
OH! I see, it's the fact that it was made in Lansing...
The block has #'s 396021F that tells you it's a 455 and the #'s on driver side block is 32M470470 that is coded like this, 3=Olds, 2=1972, M=Lansing Mi. W-30 motor.
From a pure performance aspect that thing is a pig. I had a similar set up that ran low 12's in a heavier car. Mine even had a wiped thrust bearing and ran better. That makes me think something is wrong with it. Walk away from this.
Fyi
I am 99% sure that this is not a W-30 sourced engine.
Every 1972 W-30 VIN that I have seen are in the 1XX XXX or 2XX XXX series. Example there was a Silver 1972 W-30 4 speed on eBay a week ago. The VIN for that car is 3G87X2M133471. I have VINs for over 50 1972 W machines & they all end X2M1XXXXX or X2M2XXXXXX. On this engine there is a number 4 right after the X not a number 1 or 2.
My car was built June 29th 1972 & is one of the last cars built (not the last X code car but possibly the last 4 speed car). The VIN ends X2M254XXX. No way that a W machine built after mine would have a VIN that jumps all the way to the 4XXXXX series.
So...the seller is full of shyte!
W-30 455
Thanks all -
My original post did have in mind the Craiglist ad that Texas442 posted. For reference, I am copying the ad below. From what research I have done and you all have confirmed, even if this was a W-30 engine, it has been reduced to a "standard" 455 since all the W-30 goodies have been removed, except possibly the big valve Ga heads, which we cannot tell are even still on the block.
I'm giving the seller the benefit of the doubt here...he may have gotten the info used in the ad from a prior owner.
Original Craigslist ad...
Complete numbers matching 1972 Olds Cutlass W-30 455 engine & transmission with 39k original miles. The car was hit from behind and destroyed beyond repair. The engine has some performance parts added like Comp Cam, Comp lifters, light porting on the heads, Cloye's double roller timing gear, Melling oil pump, Edelbrock intake & Moroso Chrome Valve covers along with Headers. The transmission is a 400 Olds turbo with a 2800 stahl convertor. The car ran 12.60's with all original body and interior. 3400-lbs.
I was originally going to find a 1972 W-30 Cutlass to build, but just don't have the time right now. I hate to see it go to waste sitting in my garage. This is a rare find. I found W-30 short block that sold for $3500. This motor is complete intake to pan along with the transmission. Just drop it in, install your carb and go!
Misinformation at its finest- the CL ad that is.
Agreed that the 4xxxxxx VIN sounds more like a Toronado series motor.
M means Michigan, which all W30's were.... but so were millions of not-W30 engines.
One route- OW trans with VIN stamp that matches engine's
That's reasonable evidence.
Less convincing would be measuring the intake valves to the nearest 0.001", and checking the block bore size stamps- exceedingly unlikely that any factory not-W30 engine would have more than 1 bore stamped "D" - A, B, and maybe C were the norm.
oldspackrat
April 26th, 2014 04:38 PM
Fastbrianman
Wheels and Tires
21
July 1st, 2012 09:08 AM
nelsontj
July 5th, 2010 02:02 PM
