'70 carb recommendations
Old Mar 25, 2011 | 09:10 AM
Jacoz70442's Avatar
Hello everyone,
My '70 442(convertible) 455 has been rebuilt with a very mild cam and bored .040 over. I replaced the stock intake manifold with an aluminum W-30 intake. Engine rebuild was top to bottom. Putting an OAI hood and aircleaner assembly back on, but looking for carb suggestions based on below:
1. Trying to keep a more stock appearance(aluminum intake gives away that's it's not totally stock already, so cat's out of the bag), but no chrome "look at me" carbs as it's gonna get buried anyway
2. Clearance is a problem as I understand from reading some posts
3. It's hooked up to TH400 w/A/C and most power options
4. 3.42 gears in back w/posi, otherwise stock
5. I found original carb was 7040257, but Sparky(and others) tellign me they are getting out of control and being faked a lot and my last name isn't Gates, Trump, Buffett, nor Sheen
Thanks for the help as always and if i'm off on something, please let me know.
-Ryan
Old Mar 25, 2011 | 09:40 AM
Aceshigh's Avatar
I'm definitely not a carb expert , just posting what I've read and my limited experience.
Easiest for newbies and street usage is an Edelbrock IMO.
You install it, and go, and hardly ever have to worry about it again.
Holley's are alot more tunable and people favor them for racing, but can get out of whack.
Q-jets are more finicky but seem to be favored here. I've heard bad things about them everywhere but here.
Old Apr 13, 2011 | 03:01 PM
Jacoz70442's Avatar
Anybody else have suggestions? I have stock W/Z manifolds as a side note. Thanks!
Old Apr 13, 2011 | 03:05 PM
With the Edelbrock carb you may have to run a space and run into problems with your air cleaner to hood clearance. So you might want to rethink your Rochester choice!. Let the others who have been there n done that chime in!
Old Apr 13, 2011 | 03:35 PM
oldspackrat's Avatar
I was just doing some reading in Cliff Ruggles book-How to rebuild & modify Qjets & saw that about any mid to late 70s Qjet can be rebuilt & modified pretty easily & will work great for your application. A lot of people dog them, but that's because they don't know how to properly rebuild &/or tune them to their particular engine. If you're half way mechanical, get the book & read up on it & maybe try rebuilding one yourself?
Good luck.
Old Apr 13, 2011 | 04:34 PM
Jacoz70442's Avatar
Good ideas. Who else has done this? What CFM would you use? Thanks again for all the help, guys!
Old Apr 15, 2011 | 12:30 PM
Jacoz70442's Avatar
TTT...thanks!
Old Apr 15, 2011 | 01:09 PM
alek72us's Avatar
Olds Dreamer
Yes do the q-jet. tuned right will run up side down. 7-800 cfm. and they are easy to tune.
Old Apr 15, 2011 | 04:07 PM
Jacoz70442's Avatar
Thanks, I'll be looking Q-Jet now. Anyone know what model number will work for an 455 w/auto and OAI?
79Cut2Tone
Jul 21, 2015 08:05 PM
oldscharm
Nov 11, 2009 07:42 AM
mwmjr
Feb 15, 2007 06:58 PM
1BAD68"S"
Dec 2, 2006 04:48 PM
1BAD68"S"
Aug 24, 2006 07:41 PM
