'70 442 Oil Dipstick Tube
Old Dec 16, 2013 | 09:39 PM
DRXOLDS's Avatar
Hello,
Bought a new engine oil dipstick tube from on Inline Tube. Exact dimensions...but still loose in the hole on the block any thoughts?
All dimension on (new one) the 3 dimples to press fit were within .003" on the fat side. The old one was bent and was a pain to check the oil.
Thanks in advance.
DRXOLDS
Old Dec 17, 2013 | 06:16 PM
Funkwagon455's Avatar
Perhaps the dipstick tube had broken off flush at one point and the mechanic reamed the hole oversized. Then installed the new tube intentionally bent to swage it in the block. Any sealant on the old tube? Pics might help folks troubleshoot the problem.
Old Dec 18, 2013 | 12:53 PM
How loose is it? On the last tube I installed, I sanded down the bump so it was an easy slip fit, wrapped Teflon tape around the bump area, then jammed it into the block. It fits snugly but I can easily remove it if necessary.
Old Dec 18, 2013 | 01:01 PM
jensenracing77's Avatar
I was told this by 2 differant people and Now I hear it from you.... I think they are made to loose.
Old Dec 18, 2013 | 04:56 PM
slam1918's Avatar
not that loose, I had to tap it in with a ball peen & wood block
Old Dec 18, 2013 | 10:53 PM
DRXOLDS's Avatar
70 442 Dipstick Tube Install
Thanks for the input guy's. We'll give it a try.
DRXOLDS
dantecl
Oct 27, 2013 02:50 PM
JSGD1966
Feb 11, 2011 06:37 AM
2blu442
Sep 27, 2010 05:41 AM
Clipperet
Jun 2, 2010 05:11 PM
crazy'boutOlds
Aug 5, 2009 07:55 AM
