69olds toronada 455 into a cutlass?
Old Aug 25, 2013 | 04:32 PM
Dbechtel71's Avatar
hello can anyone tell me if I can put a 455 from a toronado into my 1970 cutlass? are they interchangeable? thanks
Old Aug 25, 2013 | 05:10 PM
svnt442's Avatar
Yes. You will either need a starter for the cutlass or to change the nose on the Toro starter to a RWD nose. Also make sure to remove all of the Toro mounting hardware and use the engine mounts for the 350 in your Cutlass. You will also need to use the Exhaust for the Cutlass as the Toro manifolds are incompatible.
If you want to use headers that's OK too.
You can probably get by with the TH350 for now, but unless its had some work done to it I would either have it gone through and beefed up a bit, or source a TH400. If you do the latter you will need a new drive shaft and yoke as well as parking brake cables (if you use them) because the crossmember needs to move back for the TH400.
Old Aug 26, 2013 | 09:58 AM
Dbechtel71's Avatar
how about the oil pan? thanks for the info
Old Aug 26, 2013 | 11:14 AM
The oil pan clears. You do not need to change it. Use the accessory brackets, pulleys, and water pump from the 350 as a matched set on the 455. Use the 350 motor mounts that match your frame mounts (Anchor P/N 2261 if you need new ones). You will either need headers or exhaust manifolds for a 455 in an A-body. Swap the nose from the 350 starter onto the Toro starter to make a high torque RWD starter. That's about all there is to it.
Old Aug 26, 2013 | 11:22 AM
sicky olds's Avatar
NôôB
What about the oil filter adapter piece? Arent they different and should be swapped out?
Old Aug 26, 2013 | 11:26 AM
oldsguybry's Avatar
NOVICE car nut
You swap the adapter with the one off of the SBO .
Old Aug 26, 2013 | 11:31 AM
You are correct. Sorry, I forgot about that.
Old Aug 26, 2013 | 11:36 AM
sicky olds's Avatar
NôôB
I know it was mentioned to swap out the accessory brackets and such, just wanted to make sure on that one as well
Old Aug 26, 2013 | 06:12 PM
Dbechtel71's Avatar
thanks for the info? are the toro engines about the same in HP vs the same year delta 88 455? thanks again it is greatly appreciated
Old Aug 27, 2013 | 07:03 AM
Toros were Oldsmobile's top-of-the-line and the engines typically were rated a few HP more than the equivalent engines in full size cars. Don't confused rated HP with actual, however.
Old Aug 27, 2013 | 09:23 AM
Octania's Avatar
Meh.
Wrong thread, sorry
wc62
Oct 27, 2013 04:33 PM
bbolds442
Jun 19, 2013 12:53 PM
LI Olds
Nov 29, 2012 04:11 PM
The_Jeremiah
Jan 2, 2009 07:08 AM
68conv455
Nov 24, 2007 05:47 PM
