68 455 value?
Old Aug 15, 2008 | 08:00 AM
bullet1's Avatar
68 455 value?
i have a chance to buy a 68 455 c heads complete engine out of old ambulance with 65,000 miles on it what should it be worth asking $650.putting in 71 cutlass s project.has 350 in now my old cutlass from high school i actually got back.have several friends with 383.406 and408 chevys i need to keep up with.dont think 350 will cut it
thanks for any help.
Old Aug 15, 2008 | 11:25 AM
citcapp's Avatar
This is ok price for an engine with the C heads. Because of its use it most likley need a rebuild. Lots of short trips takes its toll on an engine. Good luck with your project.
Old Aug 16, 2008 | 08:31 AM
Toro68
Guest
Posts: n/a
That is a reasonally price for that 455(with C heads)
Old Aug 19, 2008 | 11:45 AM
delta881972's Avatar
how do you tell if "c heads"? i just picked up a 455 for free. want the intake+carbs but was gonna sell the rest.
Old Aug 19, 2008 | 01:16 PM
The large raised letter near the no. 1 and no. 8 spark plugs.
Old Aug 20, 2008 | 05:09 AM
Oldsguy's Avatar
Past Administrator
Intake and carbs? what kind of setup is it?
Old Aug 20, 2008 | 02:43 PM
theres a weiand intake with a pair of 750 double pumpers on it. heads look stock (from the outside anyway) still painted th olds met blue. im assuming theres been some work done inside. not sure what alls inside the motor
Old Aug 21, 2008 | 05:04 AM
Oldsguy's Avatar
Past Administrator
A tear down would be the only way to know for sure. I have seen almost stock rebuilds in show cars that had too much carburetor like that, you never know...
Old Aug 22, 2008 | 09:33 AM
my heads are marked with a large raised 'J' . what does this mean and how do they compare to the 'c' heads?
Old Aug 22, 2008 | 09:38 AM
442scotty's Avatar
"J"heads are smog heads 74-76 olds I believe. No comparison to the C heads...Not good for a buildup
Old Aug 22, 2008 | 02:37 PM
I've heard the J heads are fine for a mild street rebuild. If you have C heads available then use those, but if Js are all you have they will do great unless you race it all the time.
Napoleon Solo
Apr 24, 2013 11:02 AM
saved2az
Mar 11, 2012 01:52 PM
ozbie
Nov 17, 2009 12:41 PM
but08
Nov 14, 2009 06:59 PM
smcurro
Jan 28, 2009 09:00 AM
