66-67 400 or 425 choke help
Old Feb 2, 2014 | 01:28 AM
nsnarsk65cutlass's Avatar
Since i've not had any responses from g.d post .i'm looking for the choke rod lenght that goes from the divorced coil to the carb linkage,if no one has one off,can i get a picture.I just need to know if when the choke is full closed is the rod at the stop on the t-stat coil?I'll go from there. Thanks Nick
Old Feb 2, 2014 | 07:19 AM
1970supremevert's Avatar
Nick
I will be at the storage unit to day and get you some pics
Pat
Old Feb 2, 2014 | 07:31 AM
Rocketguy's Avatar
Hello,
Here is a pic of the chokestat. If you need a new one Warpath has them.
This one was actually damaged by Thorton restorations and had to be replaced. One because they had it plated and it ruined the bi-metal spring, and two they somehow bent the rod.
The correct rod is on the bottom.
Here it is as installed:
Old Feb 2, 2014 | 10:00 AM
Thanks Rocketguy but i'm looking for quadrajet pics.Nick
Old Feb 2, 2014 | 10:26 AM
Rocketguy's Avatar
If pat does not get you some soon enough I will.
Did you see this?
Pretty crazy.
Old Feb 2, 2014 | 11:12 AM
carb linkage
last picture is of choke the rod went thru the top hole
part # listed on stove is 29984 I found one on e bay(not mine) e bay item#
380426003040
Old Feb 2, 2014 | 11:50 AM
Ok thats what i was looking for the shape and the approximate rod length,looks like 2 inches.Thanks 1970supremevert,and Rocketguy.Those t-stats are pricey.Nick
Old Feb 2, 2014 | 12:25 PM
nicks1966's Avatar
nick
Pulled two out today, one 66 & one 67.
the 66 is 2.19 long
the 67 is 2.60 long
pm me your address, bent up a copy of each out of 1/8 tig rod for you to try. both are close but not perfect.
Old Mar 27, 2014 | 04:51 AM
bigretic's Avatar
Just picked up a 66 starfire with the 425. choke stat and arm is missing. sucks, because I have to open the hood and manually fiddle with it to get the choke locked in to start the car.
Anyone know which electric choke kit from jet will work with that mv4 carb?
thanks, damon
Old Mar 27, 2014 | 10:31 AM
bigretic's Avatar
So I called Jet Performance this morning and they tell me that I have a divorced choke setup and there is no electric conversion kit for those, you have to have an air tube style.
Now what?
Anyone have a source for a divorced choke assembly (with rod and cover) for a 66 425 that's not hundreds of dollars?
Here's what I'm looking at:
Old Mar 27, 2014 | 12:15 PM
tru-blue 442's Avatar
Old School Olds
1st off, I feel your pain.
I set my 66 BB up with a 67
7027156 carb. The 66 q/j, with the toliet
bowl flush is a pos and fire hazard, period.
I have found the 67, which are supposed to
be adjustable, for around $60 plus ship.
too rich for my blood. I may be wrong, but
I'll keep looking. Just takes a little longer to
warm up is all.
Here's a few pics if you can use them.
My "stove", is a 66 and the rod has been
molested badly. It's not hooked up.
Good luck with it, if you can get the
divorce choke dialed in, they are sweet.
Old Mar 27, 2014 | 01:23 PM
stan 65 cutlass's Avatar
could always go oldschool and put a manual pull wire on it
Old Mar 27, 2014 | 01:30 PM
Old School Olds
This is true, would look old school
with a little *** sticking out of the lower
dash. Not me.
Old Mar 27, 2014 | 02:04 PM
bigretic's Avatar
last resort...
Old Mar 28, 2014 | 09:46 AM
bigretic's Avatar
ok, now I'm scratching my head. I need to find a carb guy.
Upon further inspection, It looks as if I have the original intake on the car for a divorced choke, but I found the carb stamp and it is
17058213
1818 BJB
Which indicates that it is a 1978 production carb from a Chevy. At least I don't have the supposed fire hazard you guys are talking about!
Anyway, from what I'm reading, that carb should have an electric choke and possible 2 pulloffs? I'm not sure, but trying to figure it out.
Old Mar 28, 2014 | 12:37 PM
Old School Olds
I can't get my carb site to come up.
I think you are right, Chevy, wrong
for your Olds. You could maybe jerry-rigit,
but I would hunt for a 7027156 if it were me.
The 1st pic I posted shows the choke 'pull-off.'
It is the white pastic vacumme diafram with the
short piece of vac line, just lower left of the fuel line.
The choke 'stove' is the black metal piece with the
molested rod. This is the piece you are missing in you pics.
Good luck with the quest, some think it is half the fun!
Old Mar 28, 2014 | 02:57 PM
bigretic's Avatar
well, I was wrong, it's still a divorced choke carb. I was able to hunt down a spring/stat coil and rod, but it's going to take some mods if it will even work. $20 experiment.
Old Mar 28, 2014 | 04:59 PM
Old School Olds
Your carb came up as 78 Chev. GMC & marine.
For a 350 V-8.
Old Mar 28, 2014 | 06:21 PM
steverw's Avatar
Ok if your still in need heres what your looking for
Old Mar 28, 2014 | 06:24 PM
steverw's Avatar
more
Old Mar 28, 2014 | 06:29 PM
I have it handled already,nicks1966 hooked me up,but thanks for posting.steverw.Nick
Old Mar 28, 2014 | 06:30 PM
steverw's Avatar
more
Old Mar 28, 2014 | 06:44 PM
Old School Olds
PM sent Steve.
Old Mar 29, 2014 | 04:56 AM
bigretic's Avatar
SteveRW, thanks for the photos - that definitely clears up some of the mystery. Looking at those, even if I had one, its not going to work with the carb I have. The linkage is in a completely different location. Thanks for the photos!
240 Gordy
Oct 11, 2020 10:04 AM
2Olds4U
Sep 11, 2013 07:29 PM
ros6872
Aug 28, 2012 09:32 AM
Gearhead442
Nov 22, 2010 10:34 PM
ctrain22
Aug 19, 2009 11:56 PM
