65 442 Carb question
recently bought a nice 442, but has a later year carter on it - not a spreadbore. want to go to a qJet. any thoughts on what is best model # and year for 65 442 with 4 speed, no AC car ? car in good condition, think engine is factory specs. thank you ! david 310 6173070
The new Edelbrock AVS2 seems like a very good replacement, annular boosters on the primaries, 500, 650, & 800cfm models. Electric choke available and square bore design plus adjustable secondary air valve opening spring. I love qjets but for your application I'd consider this bolt on and go carb.
FYI, 1966 was the first year that Olds used a Qjet. Prior years, like your 65, came with the square bore Rochester 4GC. The AFB and clones all bolt directly to the stock intake. You would need to change the intake to use a Qjet, and then the throttle linkage would require fabrication.
Thank you
