455 W30 build
Old Mar 19, 2021 | 02:15 PM
cutlassefi's Avatar
455 W30 build
Just got done with a real F headed 455 W30.
I lowered the compression to 9.8:1 as well as reducing the off the seat time on the cam by about 30* on both intake and exhaust.
Ran it on 91 E10 with bone stock intake and exhaust manifolds as well as pretty stock heads. Cam is a mild hyd roller, specs are 228/234@.050 on a 112. Lift is .555 on both, 34* total timing
Might try something more testing tomorrow but we’ll see😉.
Hope this helps.
Old Mar 19, 2021 | 03:03 PM
Made it a little easier to read.
Old Mar 19, 2021 | 03:21 PM
OLDSter Ralph's Avatar
Joe P, Thanks.
Old Mar 19, 2021 | 03:23 PM
Joe P, Thanks.
My neck was getting sore.
Old Mar 19, 2021 | 03:41 PM
cutlassefi's Avatar
Yeah I don’t know why it loaded like that, thanks.
Old Mar 19, 2021 | 05:12 PM
VORTECPRO's Avatar
Finally a thread I can sink my teeth into. This data above is very similar to a 1970 W 30 rebuild a customer sent me a while back. Can you post pictures?
Old Mar 19, 2021 | 05:24 PM
HolleyGreenGiant's Avatar
wow, with stock intake and exhaust, huh? crazy
Old Mar 19, 2021 | 05:36 PM
cutlassefi's Avatar
Yes bone stock, totally untouched.
Old Mar 20, 2021 | 05:50 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Was that the stock Qjet carb?
Old Mar 20, 2021 | 12:10 PM
Ap6954's Avatar
Hope this helps.
I know this... Nice numbers that are I am sure held back a lot by the stock Intake and exhaust manifolds. Appreciate the build Mark and can’t wait to get it on the butt dyno. LOL.
Old Mar 20, 2021 | 03:38 PM
cutlassefi's Avatar
Yep, with a host of issues initially.
Old Mar 20, 2021 | 03:46 PM
cutlassefi's Avatar
Ok, so I had the opportunity to go from the W Z manifolds and 2.25” pipes to headers and 2.500” pipes. Anybody want to guess the HP/tq difference and where in the rpm range? REMEMBER, stock intake, stock exhaust, OPEN crossovers, Hint, I was genuinely surprised based on my previous experience doing the same comparison on other builds.
Let the speculation begin!!
Old Mar 20, 2021 | 03:52 PM
From your comment, I'm guessing a much smaller improvement than expected, like 10-20 HP?
Old Mar 20, 2021 | 04:00 PM
cutlassefi's Avatar
Ok that’s your guess on HP but what about Tq and where in the rpm range was the biggest difference?
Old Mar 20, 2021 | 04:05 PM
Pure guess would be 20-30 ft-lb. I'm kind of torn about the RPM range. I can make a case for low and for high. Given that the intake side is probably choking the high end, I'm going to say biggest improvement at the bottom of the pull.
Old Mar 20, 2021 | 04:12 PM
cutlassefi's Avatar
Ok we have one entry, anyone else?
Old Mar 20, 2021 | 04:24 PM
I’ll guesstimate an improvement 28 lbs ft at around 3300 rpm, snd 35 hp at 5200. Is that a specific enough guess?
Come on guys, share your guess. This is much more fun if everyone shares their thoughts.
I have the Jeopardy theme in my head.
Old Mar 20, 2021 | 04:51 PM
cutlassefi's Avatar
LOL! Thanks Matt!
Old Mar 20, 2021 | 05:09 PM
VORTECPRO's Avatar
A friend of 442 Dude on here dyno tested a rebuild of a stock 1970 W-30 455, with and with out exhaust manifolds, maybe he can post the article he sent me.
Old Mar 20, 2021 | 05:13 PM
cutlassefi's Avatar
If you’re going to post, just make a guess for crissakes.
Old Mar 20, 2021 | 05:26 PM
VORTECPRO's Avatar
Question
19 hp
Old Mar 20, 2021 | 05:41 PM
4+4+2=10's Avatar
40 lbs ft at around 3500 rpm, and 45 hp at 6200.
Old Mar 20, 2021 | 05:46 PM
Peak HP: 440-450 HP, @ 5600 RPM's. Peak Tq 500 @ 3000 RPM's.
Old Mar 20, 2021 | 05:53 PM
cutlassefi's Avatar
19 hp
The question was HP AND tq, and where. Christ.
Old Mar 20, 2021 | 07:39 PM
I say 31 hp at 5100 rpm and 29 ft/lbs at the first real number at the bottom of the scale.
Old Mar 20, 2021 | 10:18 PM
v8al's Avatar
Registered Olds Owner
I'll go:
+27 TQ @ 3500
+32 HP @ 5100
Old Mar 21, 2021 | 05:55 AM
Is this for Mark's new TV show, Rocket Masters?
Why do I feel like this is the Dulcich role?
Old Mar 21, 2021 | 06:26 AM
442Dude's Avatar
VORTECPRO......here is the article you were referring to. It was written years ago but shows all the empirical data between the manifold vs header torque/HP test at altitude.
File Type: pdf
Old Mar 21, 2021 | 06:50 AM
cutlassefi's Avatar
Lol, I wish!
Here you go guys. I have a theory about why the results are what they are as well as the effect that an open exhaust cavity has on power and tq and where.
The top pull was done with 34*, the bottom pull was with 32*, go figure.
Old Mar 21, 2021 | 06:54 AM
VORTECPRO's Avatar
Old Mar 21, 2021 | 06:55 AM
  #31
Lol, I wish!
Neither my eyes nor my monitor are that good...
Old Mar 21, 2021 | 07:55 AM
  #32
W/Z manifolds are better than most factory exhaust manifolds, due to the internal runners. I'd guessed that the short "tubes" in those manifolds would actually be biased towards the high end, thus the lack of improvement with headers there. I'm curious why the headers seem to nose over at the top end. Is there some weird resonance in the long-tube primaries?
Old Mar 21, 2021 | 08:04 AM
  #33
VORTECPRO's Avatar
Does this dyno print sheets?
Old Mar 21, 2021 | 08:26 AM
  #34
cutlassefi's Avatar
I pulled the throttle back a little prematurely on that run, sorry.
I believe the better scavenging of the headers pays off more at the bottom end because of the open cavity in the heads and intake and the overall traditional effect headers have on an engine. Add to that, as you pointed out, the intake tract on this is somewhat challenged, hence the minimal gain up top.
Old Mar 21, 2021 | 08:51 AM
  #35
VORTECPRO's Avatar
Can you type the numbers out so they can be read.
Old Mar 21, 2021 | 10:52 AM
  #36
cutlassefi's Avatar
Final numbers
HP TQ
3500 350 525 Peak TQ, kinda
4000 386 507
4500 411 480
5000 421 442 Peak HP
Old Mar 21, 2021 | 10:55 AM
  #37
VORTECPRO's Avatar
Talking
EFI's Dulcich would be 307 403 Olds
Theres really no reason EFI shouldn't start making dyno videos
Old Mar 21, 2021 | 12:43 PM
  #38
cutlassefi's Avatar
Maybe this one is better? And of course it loads sideways, sorry guys.
Old Mar 21, 2021 | 12:44 PM
  #39
VC455's Avatar
Barely Registered
You don't know why he chooses not to do that. You're starting those passive aggressive statements again.
I've read some of your other posts and am impressed with what you have done. You have nothing to prove, so don't act like you do.
Again, this is not ROP--drama is not considered a benefit here.
Old Mar 21, 2021 | 01:47 PM
  #40
