455 victor intake.
Old Jul 10, 2009 | 08:14 PM
442_Mustang's Avatar
455 victor intake.
Ok, Tonight we dynoed my engine. 460 hp and 534 tq. Nice flat tq curve. We found another 28 hp above that with a 2 inch carb spacer and more torque as well but I'm thinking that won't fit under my hood and I'm more interested in the numbers as it is in the car. My motor and dyno guys tell me I need a better intake. I have the torker. I see there's a Victor intake but I wonder will that fit under the stock non ram air hood?
P.S. actually it was only 459.9 hp but close enough fer me.
Old Jul 11, 2009 | 06:00 AM
cutlassefi's Avatar
455 Victor
What were the rest of specs on your build? I'd be very interested to know as I may be headed down that Big Block road.
I'm sure someone on here may have that info but you can always check the Edelbrock website, it'll give you carb pad height dimensions for both the Torker and the Victor and go from there.
Old Jul 11, 2009 | 06:42 AM
2blu442's Avatar
I don't know off hand but a method I've heard of is to take a lump of modeling clay and put it on your air cleaner. Close the hood, then take out the clay and measure the thickness. You can then compare the intake you have now with the height of other intakes you are considering knowing how much room you have to play with. John
Old Jul 11, 2009 | 08:56 AM
Danny Wiseley's Avatar
I've read several places that there's no way the Victor will fit under a stock hood (with a carburetor on it.)
Old Jul 11, 2009 | 03:35 PM
BosMobile's Avatar
Red face
I wonder??would it be wrong to run without a hood?just kidding ,but i've thought about it.Later,BO
Old Jul 11, 2009 | 03:46 PM
agtw31's Avatar
run a 3" or 4" cowl hood
they are cheap
Old Jul 11, 2009 | 08:09 PM
mildly ported Edelbrock heads,Comp Xtreme energy cam, 240/246@.050 JE pistons 10.7:1 CR., Balanced assy, Comp Pro magnum rockers , 750 Demon carb.Melling Standard oil pump.ARP fasteners
Ran sweet on dyno. Plenty fat torque band. I forgot the sheets at the dyno because my engine builder threw out his wussy back loading my motor! he's watching me type this but too hurt to do much to me.lol
By the way, the engine was plenty sensitive to timing. 32 degrees total timing. plus or minus 1 degree was 12 hp and 14 ft/lb torque. VE was around 97.5 through the range.
Should rock pretty good but the lure of more power with a spacer or better intake if I can pack it under the stock hood would be tasty.
Old Jul 11, 2009 | 08:33 PM
cutlassefi's Avatar
455 Dyno
Thanks for the info. It's a dead giveaway that you need more intake/volume. Whenever you gain 28hp by adding a spacer, that screams you need more airflow and/or plenum. Good luck in trying to adapt the Victor to your application. I'm going EFI so the shorter Throttle body might allow me to use the Victor, we'll see.
Thanks again.
Old Jul 11, 2009 | 09:12 PM
BIGJERR's Avatar
I bleed Oldsmobile
No it will not fit.............Thats why I have a cowl hood..........Theres people running 9 second quarter miles with Torkers that are gasket matched.........Jerr
Old Jul 12, 2009 | 07:36 AM
My dyno guy said I had a nice combination that ran really well but said that a similar combination on a chev or mopar would be around 550 hp plus or so. My motor guy is a bit disappointed that we missed 500 hp as well. Where is there more power to be had that would fit under the flat hood? I've read a couple articles that talked about how easy that was to do Was that just magazine hype? I know my engine builder does good work. I've personally seen 930 hp from a SBC 441 CI for a super gas car and quite a few 500+ hp mopars and chevs and fords. What is the peculiarity to Oldsmobiles?
Old Jul 12, 2009 | 07:57 AM
agtw31's Avatar
put a 100hp shot of spray in it.
Old Jul 12, 2009 | 08:14 AM
cutlassefi's Avatar
455
The fact that you gained 28hp with the spacer also tells me you need more carb. It could handle an 850 easily.
Head flow is key. I know Bill T. says flow isn't everything but maybe how well it flows at all lifts.
Here's one for you, I did EFI on a 427W Ford, Specs were, 9.2/1, the same cam specs as yours except is was a hyd roller, Eight stack 2-1/8 Hilborn Manifold and Yates heads that were $10,000.00 bare. Yes 10K.
Motor made 621hp@5900rpm, and even with the 8 stack it made 535ft-lbs of torque at 3500rpm, on 91 pump. So much for no low end torque on big manifolds. The heads were the key.
All from a 427 Windsor Ford with 9.0/1. Not bad IMO.
Old Jul 12, 2009 | 11:15 AM
64Rocket's Avatar
Put an 850 hp on it. Do some port work on the intake. Weld up the #1-2 -7 -8 runners at the dog leg and fix the kink at that point.
Gene
Old Jul 12, 2009 | 12:31 PM
BIGJERR's Avatar
I bleed Oldsmobile
X2 on abigger carb to start.........
Gerald Nickels
Sep 4, 2014 02:14 PM
krooser
Feb 4, 2013 07:37 AM
Dshelvy
Dec 14, 2011 06:15 AM
svnt442
Jul 17, 2011 04:43 PM
dejavu442
Jul 6, 2011 06:32 PM
