455 - oil pump primer
Old Jun 16, 2011 | 05:04 PM
442RAGTOP's Avatar
Post 455 - oil pump primer
Hello to all - I have a 1970 455 block which has never been started since being rebuilt. I am looking for an oil pump primer kit that will prime the oil pump and bottom end but also the lifter & rocker assemblies. They also come with a collar which eliminates any wobble when rotating the shaft.
I find numerous 'GM small & big block' kits but none that specifically reference an Oldsmobile block.
I have (2) questions:
  • Will the 'GM' kits fit an Olds big block?
  • The attached drill is rotated 'conter-clockwise' - Yes
I am a bit lite on experience here & would appreciate any assistance - many Thanks!
Old Jun 16, 2011 | 05:32 PM
willj's Avatar
priming engine ,
hi, i just did this , bought tool at napa to fit in drill, used a good drill, and turned counter clock wise , let pressure go to 60 ,for three minutes , started engine ,never heard any lifters or any raps , worked great , good luck,will.
Old Jun 16, 2011 | 05:47 PM
1968Cutlassfallbrook's Avatar
Well if you have an extra dist that you could take apart you could use it with a drill and that will prime your oil pump and all.
Old Jun 16, 2011 | 05:48 PM
442RAGTOP's Avatar
Hi Will, If your pressure went to 60, the NAPA tool must have the collar attachment included. Was the tool specific to Olds or just GM. Thanks for the feedback
Old Jun 16, 2011 | 05:52 PM
442RAGTOP's Avatar
True, but I do not think the oil pressure will ever build up with just the distributor- correct? I'm trying to verify / pre-test that also. Thanks for the feedback
Old Jun 16, 2011 | 05:54 PM
If you take the distributor apart and use the shaft with a drill it will raise the oil pressure at least that's what we did with my friends small block chevy.
Old Jun 16, 2011 | 06:25 PM
jensenracing77's Avatar
i just taped a socket to an extension and put the extension in a drill.
Old Jun 16, 2011 | 06:43 PM
TripDeuces's Avatar
5/16 socket on a long extension should do it. Make sure the socket doesn't come off
Old Jun 16, 2011 | 07:32 PM
Run to Rund's Avatar
I duct tape a deep well socket to an extension, so the parts are big enough that they probably can't get lost even if the tape fails. I use a 1/4" drive ratchet to turn the 5/16" shaft counterclockwise. That gets the oil into the passages just fine, and you can hear and feel when they are full. I like to put moly cam lube on the rocker wear points, and put each lifter in a spray can lid full of oil, then depress the plunger a few times to get oil inside.
Old Jun 16, 2011 | 08:54 PM
projectheaven's Avatar
I just did this last night on my 1970 455 engine I sat into my car. It worked great. Now I'll feel a little better when I fire it up with the new cam and new upper assembly I just installed.
brandon reynolds
Oct 20, 2025 07:27 PM
science guy
Jul 25, 2013 07:50 PM
Stevec
Feb 29, 2012 06:09 PM
86pontiac
Feb 17, 2010 11:24 AM
