455 oil pump mounting
Just purchased oil pump mount studs for 455 from mondello. Was wondering what the torque is on the studs and then the nuts. Also looking at the clearance between the pump and the crank and also the rod caps is super close. Is this normal. Thanks in advance?
Here's a link: https://classicoldsmobile.com/forums...-pictures.html
