455 motor mount for 1955 super 88
Hey
My name is Kim Einar from Norway.
I have a 1955 Olds super 88 and a 455 engine that i am going to put in it.
But i need motor mounts and brackets that will fit my car and engine.
Do someone know where i can get this from that is almost bolt on??
hope someone can help me...
Kim,
you will have to fabricate your own. because of the location of the steering box on your Olds you will have to build then to attach to the front crossmember and use the first bolt mounting points on the front side of the engine and use the stock rubber mount. I have a 57 Olds and did a similar conversion a couple of years ago. Here are some pictures of the install. PM me and I will send more info
