455 going in 72 Cutlass
Old Jan 15, 2009 | 12:40 PM
egknz's Avatar
1972 Cutlass Supreme 455
good news I located Short Block 455 Olds for my 72 Cutlass currently I have a 350 olds in it what will I need from my 350 to make 455 work ??
Old Jan 15, 2009 | 01:30 PM
Water pump, fuel pump, accessory brackets and pulleys, flexplate, and motor mounts. (Do not buy "455" motor mounts, use the 350 mounts). Of course you will need BBO heads, intake, and exhaust manifolds to complete your short block.
Old Jan 15, 2009 | 01:32 PM
64Rocket's Avatar
You will need 455 heads, intake, push rods and Cutlass 455 exhaust manifolds. Everything else from the 350 Olds will work. When you say short block, I assume you are getting the oil pan with it. The small block oil pan will fit, but I have heard that there is a problem, I have never put one on, but it may be worth a try. Be sure to use the rubber motor mounts for the small block Olds.
Gene
Old Jan 15, 2009 | 02:29 PM
egknz's Avatar
Thanks and I have 1 more ??
what size and type of headers can I put on her ??
Old Jan 15, 2009 | 03:46 PM
Any headers for a 68-72 Cutlass with 455. Some fit better than others. The primary tube diameter and length should be selected to match your intended use.
442much
Apr 3, 2011 12:41 AM
Supreme68
Mar 19, 2010 07:39 AM
Willidog
Oct 4, 2009 04:18 PM
bigcountry1009
Oct 31, 2008 06:19 AM
nonhog
Oct 7, 2008 06:44 PM
