455 engine frame brackets
Need some help finding 455 motor mount frame brackets. My 1973 Delta 88 had a buick 455 swapped into it at some point and now I am trying to put a Olds 455 back into the car. I have looked high and low with no results. Thank you in advance for any leads!
A few things to watch (and that I didn't know):
The frame pads are RH/LH and carry different part numbers
The motor mounts carry different part numbers for 350 and 455. They MUST be interchangeable since the frame pads are the same and the block mounting holes are the same, but still...
I removed a 455, and had it rebuilt. I had to order 350 mounts for the reinstall. The 455 mounts would not line up with the pads. Crazy, same car, same motor, mounts looked the same but would not work. 72 cultass supreme.
Timcando
October 13th, 2014 11:41 AM
olddaz
August 27th, 2014 06:39 PM
TimKillinger
May 31st, 2012 09:32 AM
