455 compressor brackets?
I have a 72 455 swapped into my 87 cutlass. Will the brackets off an 87 fit this motor? If not, any advice on where to go from here as far getting some air in this car? I have access to all the components of an 87 condensor, evaporator, etc. Surely theres a bracket out there some where that will do this..
The brackets from the '87 should be able to bolt on, BUT, since the big block was not originally used in '87, there may be some fitment issues.
I do not have first-hand knowledge about this, but I would think that you might get away with it using longer belts to the compressor, so long as the compressor isn't positioned too close to the hood or the fender by the slightly wider engine configuration.
Also, if any of the brackets are attached to studs coming off of the head bolts, you will need to use smaller head bolts with the same-sized studs on them (early motors had smaller head bolts than later ones). AMK Fasteners might have the right head bolts to adapt it, if necessary.
olddaz
August 27th, 2014 06:39 PM
heavydan
May 8th, 2014 05:50 PM
Jayycobb
May 31st, 2012 05:50 AM
mhartley
March 22nd, 2012 08:34 PM
