455 carb choice
455 carb choice
I have a 455 in a 69 f85. It is a f block with e heads. Believe motor is out of a olds 88. Currently has a 2 barrel on it and has full length headers. Plans this winter are to put new rod and main bearings in, xe274 comp cams cam, either a torker intake or a Mondello 4150 posiflow intake, and a 2800 stall. I was looking at the 750 street demon carb but was told a 850 holly double pumper would work better. Which of the two should I get? Or is there a better option? Car will see its days at the strip.
Aed 750 ho
Put an AED 750 HO on it & you will love it. Great carbs. I have the 750HO & 850HO AED carbs on three of my vehicles.
http://www.aedperformance.com/ho-street-strip-carbs
The compression I believe is 9.1 or 9.5 , gears it has 3.08 stock o type axle, th350 trans. I would like to get a real 12 bolt and a th400 trans but I'm on a tight budget this year. A little of subject but is there at least a spoil for this rear end? And how would a 750 dp run with this?
I have a new in box AED 750HO I'm thinking about selling..actually I may have a buyer but haven't seen the money...
Let me get back to you on that... I need to see if the other guy really wants it. He is a good friend and I don't want to dup him. Plus he's putting it on a BBC. I will be selling a Edelbrock intake too.... It's been mounted but never fired.. I cant use the carb or intake with a factory ram air set up.
