455 Cam suggestions- Looking at XE268 or Voodoo 60802 / 60803...
Sorry for the double post (here & ROP) but I'm looking for some quick opinions.
Summit has a 15% discount code if you buy more than $500 that expires today, so i want to get an order in with some more of the big stuff i need for my motor build (still at my machinists waiting to be honed)
Looking at the Comp XE268 or one of the Lunati Voodoo Cam's to go in it 60802 or 60803, specs below.
my motor will be ~9.5:1 compression w/ headers, 3.23 rear gear initially, 3.42/3.55 eventually. Manual Transmission. Manual Brakes.
Car Craft did a olds 455 build a few years ago, using the xe268, edelbrock heads, 10.1 compression- and it put out 445hp / 510ft lbs. Dyno sheet showed 400ft/lbs at 2500. That sounds about right for what i want.
My motor won't be getting Rev'd much more than 5500 due to the heavy LF2323 pistons & stock rods, etc etc, so i want it to make all its power before then. basically torque monster.
This will be a mostly street used w/ 4 or 5 trips to the track in the summer, and i would like have enough motor to be solidly in the 12 second range (traction & my shifting ability being the limitation)
Thanks for your input:
XE268
Advertised Duration (Int/Exh): 268 /280
Duration @ .050 (Int/Exh): 224/230
Gross Valve Lift (Int/Exh): .485/.49
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range:
Voodoo 60802
Hydraulic. Torque Monster for 400-455 c.i. daily driven street performance vehicle. Excellent torque and horsepower production with heavier emphasis on the low to mid range. Will work in ski boat applications with larger 455 c.i. engines. Choppy idle!
Advertised Duration (Int/Exh): 262/268
Duration @ .050 (Int/Exh): 219/227
Gross Valve Lift (Int/Exh): .499/.510
LSA/ICL: 112/108
RPM Range: 1300-5500
Voodoo 60803
Hydraulic. High performance street/strip cam for 350 c.i. Excellent camshaft for 400-455 c.i. touring type vehicles with 9:1-9:5 compression ratio. Use 2200-2400 stall speed converter with 3.23-3.42 rear gears. Cam has a very noticeable idle quality!
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 227/233
Gross Valve Lift (Int/Exh): .510/.522
LSA/ICL: 110/106
RPM Range: 1600-5800
Other suggestions?
XE268
LSA/ICL: 110/106
RPM Range:
Voodoo 60802
LSA/ICL: 112/108
Voodoo 60803
LSA/ICL: 110/106
Other suggestions?
I had a guy grind me a roller cam for $120 to any specs i wanted so I got a mondello grind and took it to him. Thats no help with summit but just in case u miss the discount.....
Y not just have our guy on here turn you out a custom cam? It's just the same dollar wise, and will out perform anything you can buy f/ the 455 Olds. All that I've seen on this site andon BBO engines, I've come to the conclusion thru research and building my 455, that a person would be nuts to NOT go thru our guy f/ a cam. There is just no comparison. Here he is just above ,"CutlassEFI".
I opted for the Lunati 60803, Ordered on Thursday before the deal expired.
That was my original preference from a while back, but i had been rethinking things and wanted to get opinions.
Thanks for those who responded with info & comparison results, much appreciated.
Now I just need to get back to bugging my machinist to finish my block work. He does great work & cheap, but S-L-O-W....
So it was not a huge leap to be talked back into the cam I originally wanted.
Several of my close friends run UD/Lunati grinds with great results in their BBC & SBC street strip cars. The 60803 or 60804 were my original first choices from the beginning for this build. The 04 was quickly discounted because I won't have the compression or gear- then when the realities of my build set in (heavy pistons & rotating assembly making sub 5k rpm power desirable) it made me reconsider going smaller still.
Good choice nonetheless
I like the Lunatis myself as well. Careful with the BBC and SBC talk around here though, you'll get 50 lashes with a limp *cough* wet noodle for mentioning Chevy in comparison to your Olds build XD Correct, can't compare the 2, plus Olds exhaust/head flow is different than Chevys
young olds
April 26th, 2017 11:40 AM
urnightshiftpal
November 4th, 2010 01:37 PM
