455 c heads from marine engine
Old Aug 12, 2015 | 01:44 PM
GM MUSCLE's Avatar
Question 455 c heads from marine engine
Hi guys, I have a question concerning some c heads that I recently purchased. They were from a 455 and looked pretty clean until I received them and found the exhaust valves pretty pitted. The number on the heads are #394548 I asked the guy I bought them from and he then said that they came off a marine 455 engine. I did not know this before hand.Would I still be able to use these on my 400 67 442? Or did I get hosed? Please advise.....
Old Aug 12, 2015 | 02:24 PM
brownbomber77's Avatar
As long as he didn't tell you they're ready to bolt on....I don't really see the issue. I almost expect 40 year old valves to need replacing no matter what engine they came out of
Old Aug 12, 2015 | 02:45 PM
GEARMAN69's Avatar
Big valves in stainless steel are only 160 on Ebay , I would put em in any build combo especially a 455 or a 400 425 just the same . This gives you a chance to cut out any rust pits in seats on a 2.0/1.62 valve head when putting 2.07/1.71
Old Aug 12, 2015 | 02:55 PM
GM MUSCLE's Avatar
He did list them as "ready to run"
Old Aug 12, 2015 | 02:58 PM
GM MUSCLE's Avatar
So these heads should work out fine? I know I have to install new valves and check the seats.. What about the valve springs? My original heads on my E block had single springs, these have double springs and they are so tight, I can hardly compress them..
Old Aug 12, 2015 | 02:59 PM
GEARMAN69's Avatar
Bummer, maybe the seats and faces are fresh ground and seal good. Maybe do a leak test on the bench with brake fluid
Old Aug 12, 2015 | 03:07 PM
Bernhard's Avatar
When investing in core parts avoid rust scale and heavy pitting.
Look in the water passages what do you see?
Corrosion from salt water or from a engine that did not run anti freeze are a poor choice, unless very very very rare.
If they are corroded/heavy pitting don't throw good money after bad, find a clean set.
If you are unhappy contact the seller with your concerns.
Good Luck
monzaz
May 15, 2012 01:23 AM
Tedd Thompson
Dec 27, 2009 03:04 PM
4BRL69
Jun 22, 2009 07:05 PM
Topless72
May 17, 2008 04:45 PM
wizz
Nov 24, 2007 03:36 PM
