455 buildup ?
Old Jan 6, 2007 | 10:38 AM
455john's Avatar
455 buildup ?
HI,I,m John and new to Olds .I have a question on a 455 .It no longer has a valley pan and I am going to install a oil deflector to keep hot oil off the manifold, but! The stock deflector looks as if it is slowing oil to the front and rear of the eng. so the oil will flow to the center of the cam .Is there any thing to this, or am I just being to coutious. Yousee after the eng. ate every thing that moves ,I got on line and did some research and found out about the oil problem at high R's. So lets hope the 2nd times the charm. Thanks John
Old Jan 14, 2007 | 06:02 PM
Crankit's Avatar
hi john-their must be a secret way to get a reply...cause I dont know it either ...CRANK.IT
Old Jan 14, 2007 | 06:28 PM
2blu442's Avatar
Sorry guys, I don't know if that is enough to cause a problem or not. I do know there are some after market deflectors that don't channel it to the center. My guess, and just a guess is that in normal street applications it doesn't make a difference.
Old Jan 14, 2007 | 08:10 PM
texasred's Avatar
Tom Servo's Stunt Double
When you had the motor redone, did you have the drainback holes enlarged?
FWIW, I run without a valley pan or a valley deflector and my SBO with a Performer RPM intake was clean last time I pulled it.
C.J.
falconsfan
May 14, 2015 05:47 AM
Qwik71442
Feb 1, 2013 06:00 AM
Escalus2k4
Jan 1, 2008 01:53 PM
azuraz
Nov 2, 2007 08:25 PM
ooohhha442
May 24, 2007 10:34 AM
