455 build
Old Feb 6, 2013 | 10:59 PM
1973olds98's Avatar
455 build
Hello...I am just about ready to do some driving in my olds...I have a 73 olds 98 that I had rebuilt...I upgraded the points to hei..Mmy question is,,,,Would this change the timing,,,what plugs and what gap to use...Could I just use the stock plugs but use a different gap...I set the beginning timming with 0 tdc and the dist pointing at number 1...I don't have a timing light yet
Old Feb 7, 2013 | 06:41 AM
RetroRanger's Avatar
72 Olds CS
My understandingis the HEI has less mechanical advance than the points dizzy. As a result many people run the HEI w more initial timing. If the points were set at 8-10 btdc try the HEI at like 15 or so
Old Feb 7, 2013 | 08:02 PM
Your questions should all be answered in this thread (read through a few bits to the relavent parts).
In this thread, many of the same points are reiterated to a hard case who seems unwilling to read the material in the thread mentioned above.
agreen316
Dec 21, 2013 06:27 AM
wildwillie1981
Apr 24, 2013 04:19 PM
bobolds
Mar 26, 2007 02:45 PM
scr boi
Mar 12, 2007 04:40 PM
69 442 protour
Dec 9, 2006 09:25 PM
