455 bellhausing
Old Aug 11, 2023 | 10:21 AM
juan455's Avatar
455 bellhousing
Hello friends. I need to know the equivalence of the bellhausing for a 455. Can a bellhousing from another big block be used for a manual transmission?
thank you
Old Aug 11, 2023 | 12:19 PM
edzolz's Avatar
Originally Posted by juan455
Hello friends. I need to know the equivalence of the bellhausing for a 455. Can a bellhausing from another big block be used for a manual transmission?
thank you
All bell housings with the Olds bolt pattern will cross reference to any modern Olds engine, small block 260, 330, 350, 403, and big block 400, 425, and 455. There are exceptions for other than A bodies.
Old Aug 11, 2023 | 01:22 PM
66-3X2 442's Avatar
thank you
I have one for sale if you need one.
Old Aug 11, 2023 | 07:34 PM
juan455's Avatar
buick and pontiac don't fit?
Old Aug 11, 2023 | 07:36 PM
juan455's Avatar
send me a message I can't do it please
Old Aug 12, 2023 | 06:48 AM
juan455's Avatar
pontiac and buick?
Old Aug 12, 2023 | 08:24 AM
66-3X2 442's Avatar
pontiac and buick?
Yes they will interchange .
Old Aug 12, 2023 | 05:31 PM
2blu442's Avatar
Be sure you get one setup for your vintage of car. I have one that is the correct bolt pattern from bellhousing to engine, but the clutch fork location is different. I believe it had a cable rather than rod linkage. If you get one from Mike he will know the right one for your car.
Old Aug 13, 2023 | 07:21 PM
Any BOP bellhousing bolts to the Olds motor. Be aware that some of the later ones are configured for the cable-style clutch linkage used in the H-body cars and won't be suitable for use in an A-body. The most common casting numbers that work are 9785581 and 547975.
zeb
Dec 2, 2015 06:54 PM
73-s
Jun 8, 2015 04:40 PM
lunaboy
Aug 18, 2014 11:21 AM
kona-jack
Aug 27, 2009 10:28 AM
chuck_royle
Jul 12, 2007 06:21 AM
