Here are some pics of the clevite main bearings in this 455 that I will be building. Do these look like they have normal wear or something else. Not sure if I should reuse or replace.
Appreciate the help., Ben
If you're not on an overly restrictive budget and this motor is going into your own car, why keep used bearings in a fresh build? 1 less major issue to worry about after all back together and running.
