425ci help
Old Nov 2, 2014 | 08:44 AM
1arunem's Avatar
425ci help
Guys,
I recently acquired a 66 model 425 (non toro from what I can tell). The engine had a stock 2 barrel intake. I have popped the intake and heads off. From my understanding there was a low and high compression version (9.0:1 and 10.25:1 maybe?). Anyway to tell from these photos of the pictures if it is high compression or low? They have a 'recess' but not sure if they are 'dish' pistons. Engine has 'B' heads.
thanks!
Warren..
Old Nov 2, 2014 | 08:53 AM
therobski's Avatar
1964-67 V-8 Engine:
Code is stamped on the right cylinder head. Unfortunately, this only applies to what was originally the driver's side head. This code consists of a prefix letter (330 V-8=T (1964-65) or W (1966-67), 400 V-8 = V), then a production sequence number, followed by a suffix code letter (L = Low compression, E = 2-bbl export, G = High compression, H = 4-bbl export). A 2-letter code on the oil filler tube identified the engine.This should apply to the 425. Most likely a low compression 425 2 -barrel I recall it being 310HP.
Old Nov 2, 2014 | 08:55 AM
therobski's Avatar
B heads indicate a 66
Old Nov 2, 2014 | 09:18 AM
Those are high compression pistons. 10.25:1. The notch is a V instead of a U.
Old Nov 2, 2014 | 09:22 AM
Octania's Avatar
HC 2-bbls are not uncommon in that era
usually the HC air cleaner is red, so black 2-bbl = LC, Red 2-bbl = HC
of course if you don't have the air cleaner then go by the piston notch, head stamp, and maybe even measure the dish and calculate its volume.
Old Nov 2, 2014 | 10:41 AM
1arunem's Avatar
Nothing I can find on drivers side head. Pass side front has an 'M' and then a sequence of numbers
Old Nov 2, 2014 | 11:38 AM
Front of the passenger side head is the correct location.
The number will be Myxxxxx (with y= 5, 6, 7, 8, or 9 and x=any digit).
Mxxxxxx with no suffix letter signifies a 1966 10.25:1, 2bbl 425.
Old Nov 2, 2014 | 11:41 AM
1arunem's Avatar
Thanks.. that is what I was hoping for..
Old Nov 2, 2014 | 01:38 PM
Oldsmaniac's Avatar
Look like HC to me....
Old Nov 2, 2014 | 01:57 PM
64Rocket's Avatar
All this info is great if your not going to rebuilding it. Once you change pistons and cam all that info is negated. Unless your doing a numbers match vehicle, but I don't think in this case.
Gene
Old Nov 2, 2014 | 02:13 PM
1arunem's Avatar
I understand. Appreciate all the information.
Ry66cobra
Apr 7, 2011 07:04 AM
UnkleScott
Jan 22, 2011 08:25 PM
mauls
Jun 4, 2010 03:40 AM
longboardguy
Apr 3, 2009 06:37 PM
EdsDelta
Jul 22, 2004 11:46 AM
