425 sudden lifter noise
Old Dec 19, 2016 | 12:52 PM
Aqua67's Avatar
Had the 67 Delta 88 out yesterday. I drove maybe 15/20 miles. I heard some engine noise as I crossed a bridge as I was returning home but it was quick and wasn't sure of what I was hearing. As I pulled in the driveway a minute later the sound was a bit more evident and identifiable..lifters tapping. I checked the oil and it was fine but seemed thin. Would an oil pump fail that abruptly?
I suppose I will change the oil/filter and start from there.
Old Dec 19, 2016 | 01:02 PM
Could be a lot of things, do you know what your oil pressure is?
Old Dec 19, 2016 | 03:15 PM
Aqua67's Avatar
No I don't know what the oil pressure is however the idiot light did not come on but I know that means very little. I don't have an oil pressure gauge handy
Old Dec 19, 2016 | 03:25 PM
I'd go purchase a mechanical and temporarily install it to find out. I would use a Napa gold or a wix filter. Since Oldsmobile engines have non adjustable valve trains it may be worn lifters or rocker pivots. Worst case an oil pump or cam.
Old Dec 19, 2016 | 03:37 PM
Tedd Thompson's Avatar
If mine I would change the oil and first and see if it goes away. I had a 63 Olds that would stick a lifter every 3000 miles. That was my reminder to change the oil. Noise would go away till the next 3000 miles.... Tedd
Old Dec 19, 2016 | 03:38 PM
Aqua67's Avatar
i can understand a lifter or perhaps 2 misbehaving but not all of them at once without a reasonable explanation such as a blockage or as you say, pump or cam. thanks.
Old Dec 19, 2016 | 03:40 PM
Aqua67's Avatar
thanks Tedd..thats' my first step. I have to change the oil anyway as i added a cap of seafoam last week. Just wondering if that has something to do with it.
Old Dec 19, 2016 | 04:12 PM
A cap or can? A can may have loosened up a bunch of crud.
Old Dec 19, 2016 | 05:49 PM
Aqua67's Avatar
[QUOTE=oldcutlass;976692]A cap or can? A can may have loosened up a bunch of crud.[/QUO
I definitely think it loosened some stuff but I only added what the directions said, think it was about 4 0z.
Supernaut72
50
Feb 6, 2016 04:59 PM
Robert Zuijdam
Apr 8, 2014 04:01 PM
pistonpop
Jan 13, 2012 04:36 PM
dster69442
Dec 3, 2010 07:50 AM
64oldsguy
Aug 21, 2010 11:01 AM
