425 pushrods
Old Sep 22, 2022 | 02:06 PM
android 211's Avatar
425 pushrods
What length pushrod do I need for a 45 degree block 425? Is it the same as the 39 degree block? Should I spring for the restricted
pushrods? Its going in a mostly stock 425 with hydraulic lifters. If the block is decked and the heads are given a minimal mill for flatness do you recommend custom length pushrods?
Old Sep 22, 2022 | 04:32 PM
Yes, always measure the length push rods that are needed for YOUR engine. Any machining to the block deck or head surfaces, different head gasket thickness, camshaft base circle diameter, and valve stem height will all affect the length pushrod needed for correct valve train geometry.
Machineit
Mar 6, 2022 06:54 AM
chadman
Jan 31, 2022 04:04 PM
Jens Palo
Mar 21, 2021 07:50 AM
Old Olds Fan
Oct 2, 2013 05:19 AM
ZASX
Jun 24, 2008 11:53 AM
