425 piston options
425 piston options
I am rebuilding a 66 425 motor and am having problems finding pistons. Anybody know a source for these and what compression ratios are available? I have also heard about using 455 pistons with big block chevy rods and machining the connecting rod journals to get the 4.25 stroke on the forged crank. Has anyone done this? How did it work and how much did it cost? Thanks, Dean
I agree the cast pistons would work. I looked at the site and could not find anything below a 10.25 compression piston. Too much for cast iron heads on pump gas and questionable on aluminum heads. Thanks, Dean
What would be the difference between the pistons in a 425 as to the 455? My guess would be the location of the piston pin. Would it be a better solution to use low compression 455 pistons with custom connecting rods? Dean
with a thicker gasket like .040 i think the compression would be lower than 10.25 to 1 . The o.e. gaskets where between shim gaskets .018 and .022 also find out the deck hight and how far in the cylinder the pistons sit. i think you would be fine running the 10.25 to 1 pistons with an .040 felpro head gasket. I think realisticly you will be under 10 to 1 again depending how far the pistons are in the cylinders head cc's and piston dish cc.
Here are some Sealed Power (SpeedPro) pistons at Summit:
http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
Interestingly, the forged ones ($53.99) are cheaper than the cast ones, but all are much more expensive than the 350 Olds cast pistons (about $27)
