425 olds engine code 389244D
Old Feb 19, 2007 | 11:10 AM
mwmjr's Avatar
Can anyone point me to some information I can find about the 425 engine. The code is 389244D and the year as far as I can tell should be 1966 or 1967.
Thanks for any help
Mike
Old Feb 19, 2007 | 06:18 PM
2blu442's Avatar
Hello Mike
Check the head casting, if it's a 1965 it'd be "A", 66 a "B", 67 a "C" That would be a letter that's maybe an inch tall located next to the #1 and #8 sparkplug holes. Check the FAQ list at the home page of this site for more details. Also, if it's a Toronado the center of the intake will be sunken and the oil pan will have a provision for the front drive axle, then a little lower in the front and the lowest part of the back will have one side lower. Should have a forged steel crank, and if a 4 bbl carb a higher compression and hp output. John
Old Feb 20, 2007 | 05:59 PM
70Wcars's Avatar
That is a 66 or 67 425...problem is that motor was available in two configurations. 45 degree lifter angle or the more common 39 degree. Also two lifter Dia. The .921 is the more pricey of the two sizes. There is a " drill spot " on the raised casting on top of the timing case next to the oil filler tube. Can you post a pic of the top showing the casting number and the area next to the oil filler?
Old Feb 21, 2007 | 09:32 AM
mwmjr's Avatar
I dont have a picture of the spot you are referencing but I will look for the drill hole.
Old Feb 27, 2007 | 11:30 AM
frdmftr's Avatar
Freedom Fighter
I posted some pics of my 67 425 motor on another thread : look under Eighty Eight section: Help, what is this? Check Images- Need Info
Is there an indicator of which cam angle this is?
FRDMFTR
Boldsmobile
Nov 2, 2011 06:02 PM
ZASX
Jan 30, 2010 05:41 AM
rrielley
Feb 9, 2008 10:43 AM
psmopar
May 7, 2007 06:55 PM
