425 compression ratio
Old Dec 10, 2008 | 07:31 PM
Oldsproject's Avatar
65 post sport coupe w/425
What should the compression on a fresh 425 with 10.25 Egge pistons be (roughly). How much variation per cylinder? I'm getting readings from about 130 - 150. But the battery was low and I didn't open the carb so will do again.
Old Dec 10, 2008 | 07:41 PM
Wireman134's Avatar
Enter your info. on your build into this calculator...
http://www.projectpontiac.com/ppsite...nt/view/16/30/
Old Dec 10, 2008 | 10:40 PM
Thanks, tried it but getting NaN in the compression columns? The following are the build specs:
Bore - 4.155
Stroke - 3.975
Combustion Chamber - 80cc
Deck Height - .015
Head Gasket - .040
Piston Dish - .045
Connecting Rod length - 7.00
Cam Intake duration - 266
Lobe seperation - 110
Also, was looking for actual compression readings not ratios (my mistake). Thanks.
Old Dec 11, 2008 | 08:07 AM
Wireman134's Avatar
There were two types of dished pistons for the 425. The 10.5:1 CR and the 10.25:1 CR, using two different dish volumes of 4.5cc and 7cc. Using a 4.5cc dished piston, your as built 425 has roughly a 10.1:1 CR. I think you needed to convert the piston dish amount to a volume in cc's to get the calculator to work. I would guess your cranking cylinder pressure with that cam should be around 165psi. With a dynamic compression of around 8.2:1 you should be able to run pump premium with the engine tuned properly.
Old Dec 12, 2008 | 06:27 PM
After getting the battery charged and running the compression tests again, I'm running 150 - 160 in each cylinder cold. Does ths sound about right on a rebuilt motor?
Old Dec 12, 2008 | 06:41 PM
dan2286's Avatar
That sounds pretty good.
classicninja
Nov 21, 2014 06:47 AM
bluecab
Feb 22, 2012 02:45 PM
greenslade
Mar 29, 2011 03:56 PM
OLD SKL 69
Jan 22, 2008 08:11 PM
Escalus2k4
Jan 15, 2008 08:29 PM
