425 build
Old May 17, 2017 | 08:18 PM
angelo68442convertible's Avatar
425 build
Hi I got a 425 with no heads. But I have a set of E heads will they work? Does anything need to be done to them? Should I look for A or B heads?
Old May 17, 2017 | 09:19 PM
The E heads will bolt up as all Olds heads (BBO and SBO) have the same bolt pattern. Do you know if your 425 is a 45º block or a 39º block? It may make a difference for push rod clearance (the E heads are from a 39º block).
Old May 17, 2017 | 11:38 PM
Gerald Nickels's Avatar
Set one E head on your engine and if the lifter hole lines up with the push rod hole your good to use. But if they are off you must grind some metal off the bottom of push rod hole in your heads to work.
Old May 20, 2017 | 11:43 AM
brownbomber77's Avatar
A beveled drill bit works fine.
https://www.harborfreight.com/3-piec...its-66463.html
agreen316
Dec 21, 2013 06:27 AM
wildwillie1981
Apr 24, 2013 04:19 PM
425cutty
May 9, 2010 01:01 PM
nickd
Jul 16, 2009 07:27 PM
69 442 protour
Dec 9, 2006 09:25 PM
