425
The one thing you WON'T need is new motor mounts, however. Simply bolt the current ones to the 455 and drop it in.
So will the accessory brackets from my 350 olds work on the 425 ?will I have any clearance issues with the hood or anything else
You need the correct exhaust manifolds or headers for a BBO. If you are running the original 307 accessory brackets, you'll need to make a couple of slight modifications to accommodate the taller deck height of the 455. If you are running the 307 starter currently, you'll want a high torque starter. You'll need a larger radiator.
It depends on which year 350 brackets you have. Brackets from cars that were built during the period when Olds was building both BBO and SBO engines typically have two sets of holes to accommodate the two different deck heights. Brackets from 350s built in the late 1970s will likely only accommodate the SBO deck height and will require mods to fit the BBO.
Depending your air filter asm. hood clearance may be tight. A Toronado iron intake will gain you perhaps an inch of room for a taller filter.
Great choice of a 425
B heads are typically seen on 1966 model year engines, not 1967.
Look for the exact application and Engine Unit Number stamp in the flat machined area on the fwd end of the RH head. Please state what that is. R100123T or similar.
Also look for the drill spot in the rib adjacent to the oil fill tube, which indicates a Tornado type D block.
steve walker
Dec 17, 2019 12:32 PM
