403 engine into 69 Toronado
I realize the 403 is a punched out 350, would it be feasible to install one into a 69 Toro with tired 455? I've got a 403 with only 40k miles that runs like new... just wondering?
The 1977-79 Toros came with 403s. Your biggest problem will probably be the exhaust manifolds. I don't know if the BBO Toro manifolds will clear the transaxle with the shorter deck height of the SBO 403. Get the manifolds from a 403 Toro and no problem. Other than that, just the normal changes from RWD to FWD configuration - oil pan and pickup, oil filter adapter, and water pump/accessory brackets/pulleys.
Just the '77 and '78 Toros came with the 403. The 403 was available in 1979, but only in the 98. The '79 Toro engine options were either the standard-equipment gasoline 350 (L34) or the optional 350 diesel (LF9). All of this is in Setting the Pace. I have a '78 Toro now, and I've suddenly become much more familiar with late '70s Toros and their engine options in the hunt for parts.
Thanks fellers, Looks like in a pinch it can be done. iI a perfect world I'd prefer to rebuild the 455 if affordable, the 403 would clearly be down on power. Weighing options on an early Toro I'm looking at with high miles.
88hurstolds
Jan 20, 2020 11:39 AM
71cutlassdroptop
Sep 18, 2017 06:09 PM
