400 E Block lunati 60803 cam
Old Jan 26, 2023 | 10:00 AM
rjh45's Avatar
Short idle video of a 67 400 E block build I did last spring.
Old Jan 26, 2023 | 10:40 AM
What's the compression ratio on that engine?
Old Jan 26, 2023 | 10:56 AM
rjh45's Avatar
It's got flat tops in it and compression is 10.1.
Old Jan 26, 2023 | 02:03 PM
android 211's Avatar
Is the cam on a LSA of 110 or 108?
Old Jan 26, 2023 | 04:12 PM
rjh45's Avatar
Cam has a lsa of 110. Engine is very snappy and responsive.
Old Feb 21, 2023 | 09:26 AM
JRSL69's Avatar
J.R.
Sounds awesome, what are you using for valve springs and rockers?
Old Feb 21, 2023 | 09:15 PM
64Rocket's Avatar
what did dial the intake lobe to ? What did the cam card say to instal intake lobe to ?
Old Feb 22, 2023 | 06:31 AM
rjh45's Avatar
Valve springs we're lunati and matched to the cam. Rockers are 1.7 scorpion roller rockers.
Old Feb 22, 2023 | 10:55 AM
JRSL69's Avatar
J.R.
So if I'm doing my math correctly, 1.7 rockers will give you 5.88% more valve lift over the listed Lunati 1.6 rocker specs. .510/.522 becomes .540/.553. Are you using cast iron heads, did you need to be concerned with the valve to piston clearance.
The reason I'm asking is I currently have a 66 400E 4spd, 3.55 gear car with B heads with roller tip rockers and the 69 W30 328/328 cam in it. I would like something now that is more street friendly but still has that sound and makes good power for cruise night.
Thanks Jim
Old Feb 23, 2023 | 04:50 AM
rjh45's Avatar
I have speedmaster heads they were cut to 76 cc and cnc ported ported by Knowlton's Thunderheads. I did not have any piston to valve interference issues. This cam pulls 11 to 12 inches of vacuum @800 rpm idle.
Old Feb 24, 2023 | 05:33 PM
67OAI's Avatar
Old(s)GuysRule
JRSL69, I would recommend the early W30/W31 (308/308) camshaft for your "E" block. It will provide adequate vacuum for power brakes, makes good power, is street friendly, sounds good, and will work with the 3.55 gear.
Old Feb 24, 2023 | 07:34 PM
OLDSter Ralph's Avatar
Originally Posted by 67oai
jrsl69, i would recommend the early w30/w31 (308/308) camshaft for your "e" block. It will provide adequate vacuum for power brakes, makes good power, is street friendly, sounds good, and will work with the 3.55 gear.
x 2
Old Feb 25, 2023 | 05:04 AM
cutlassefi's Avatar
Thanks Jim
I do a previous grind from Crane. It’s 230/234@.050 with .496/.508 lift on a 110. Sounds great, very responsive and would work well in your build. Let me know if you’re interested in doing it.
JIM'S w30
Jul 28, 2019 07:26 AM
JIM'S w30
Apr 10, 2019 04:23 PM
ut442
Jan 24, 2012 04:22 PM
442scotty
Mar 3, 2011 07:37 PM
gunmetal71
Oct 25, 2009 02:48 PM
