400 cubic inch
Old Apr 4, 2017 | 03:44 PM
1partshelp's Avatar
400 cubic inch
I have an 65 442 and I am planning on rebuilding the engine. There are a couple of things I am not sure of. I would like to put a complete roller system in it. Roller cam,lifters and rockers. Has anyone ever done it. If they have is there any information I should know. Also I am looking for a place where I can purchase some .40 over pistons. I have looked but no luck. Thanks JIM
Old Apr 4, 2017 | 05:19 PM
cutlassefi's Avatar
If it has the .921 lifter bores then you'll need to have them bushed to accept a standard Olds roller lifter.
Pistons are available thru me and others. But before you buy a set of Egge's or Kantors, weigh all your options. You'll be glad you did.
Old Apr 4, 2017 | 05:37 PM
Also be aware that most all cast pistons are shorter than the factory pistons. This can have a significant impact on the compression ratio. Forged pistons will likely be the correct height.
FYI, .057" over pistons would be standard bore 350 pistons.
Old Apr 6, 2017 | 09:56 PM
1partshelp's Avatar
400
I mic the lifter bore on my 65 400 and it is .844. Could you tell me where you found .921. I am not familiar with that one. Also if I can get .40 pistons from you who makes them and what is the cost. Thank You JIM
Old Apr 6, 2017 | 10:16 PM
I think the later E-block 400s are the ones with .921" lifters and 39º cam bank angle.
Old Apr 6, 2017 | 10:37 PM
1partshelp's Avatar
I know my cam bank angle is 45 degrees. How did you make that degree sign next to the 39.
Old Apr 6, 2017 | 10:42 PM
ASCII code is ALT 0176 (hold down ALT key while typing 0176 with the number keys).
Old Apr 7, 2017 | 06:00 AM
cutlassefi's Avatar
It also is normally shared with the no. 8 key on most computers. Shift then press the number 8 key.
I have a roller cam ground on the 45* ready to go if you're interested. I can supply you with just about everything if you like.
TripDeuces
Jan 31, 2013 08:54 AM
Stevec
Sep 3, 2012 08:42 AM
fingers-hack
Aug 15, 2010 07:30 AM
cessna195
Aug 12, 2010 08:00 AM
shaks 442 clone
Apr 25, 2007 08:53 AM
