394 broken pipe to choke assembly
Old May 8, 2008 | 06:51 PM
justinj's Avatar
When I was removing my carb for a rebuild, I managed to break the pipe that goes from the intake manifold to the choke assembly. I'm still trying to get the knack of how much force to apply without breaking stuff...
Can't seem to figure out how to remove the broken end and replace. Any ideas? I'm really hoping I don't need to take off the manifold.
-Justin
Old May 8, 2008 | 09:03 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
It is usually shaped like a J , you will probably have to do some creative bending while pulling with pliers to get the broken piece out. Hopefully it is still sitting upright in the pocket to where you can grab a hold of it with something.
As for a solution... you could always run an electric choke on ignition power if you had to.
rmoths
Jul 9, 2014 03:26 PM
88hurstolds
Mar 9, 2013 08:05 AM
805cut
Jun 8, 2012 03:15 PM
67442nut
Sep 19, 2010 12:20 PM
chaosklima
Apr 27, 2007 11:39 AM
