1974 455 Big Block
Old Nov 19, 2021 | 07:40 AM
71OldsCut's Avatar
1974 455 Big Block
Hi,
There is a 455 Engine with trans from a 1974 Olds near me for sale. Asking $280. Seems low to me especially considering it looks complete, has trans, alternator, carb, pretty much everything. I am waiting to get more details but short of have a huge hole in the block where a piston made its escape or something like that would this be a good purchase for a rebuild?
It would be replacing the 350 in my 1971 Cutlass. I was hoping for one in the 1968 to 1972 range but from what I understand this would be basically the same.
Thanks!
Old Nov 19, 2021 | 08:26 AM
cutlassefi's Avatar
How much power are you looking to make?
Old Nov 19, 2021 | 08:49 AM
android 211's Avatar
A '74 will have the less desirable 'J' heads - poor exhaust port. If it came out of a big Olds then the Turbo 400 will have a longer tailshaft than
was usually used in a Cutlass so you will have to get a short tailshaft and swap it. Other year cylinder heads can easily be swapped over or you can get aluminum heads.
Old Nov 19, 2021 | 08:51 AM
71OldsCut's Avatar
Nothing crazy. I'm not really sure what you could expect from this engine, but I think something in the 375-450 range for horsepower would be fine. There is a deal pending on this engine, but if it doesn't work out I will try to get it. It is out of a 1974 88. Mileage unknown...
Old Nov 19, 2021 | 10:23 AM
71OldsCut's Avatar
Thanks android. That's good to know about the cylinder heads. I think the plan would be for some type of after market heads so that should be fine
Old Nov 19, 2021 | 03:37 PM
cutlassefi's Avatar
If you’re only looking for 375-400hp then why a big block? My iron headed 350 Dyno mule made 405 on 91 pump. It can be done if you have a solid plan.
Old Nov 22, 2021 | 08:21 AM
TEB's Avatar
TEB
I'm in a similar situation to the OP. How much HP is a reasonable expectation for both the 350 and the 455 if you want the engine to look mostly stock (Q-jet and stock exhaust manifolds)?
Old Nov 22, 2021 | 08:41 AM
71OldsCut's Avatar
For me it's more just wanting the big block with a mild build. I don't really have a horsepower or torque number target in mind. I wanted a bit of a lumpy cam with some after market heads and whatever crank/pistons people have used with good results. Just a mild build that runs well on pump gas and the numbers fall where they fall. But am curious as well about what those numbers end up being. I know I could probably get the same numbers for my purposes out of a well built 350, but have never had a big block.
geoff442
Sep 20, 2016 09:04 AM
zeb
Dec 2, 2015 06:54 PM
lunaboy
Aug 5, 2013 08:13 PM
KTouse
May 12, 2013 01:58 PM
