1971 toronado 455
Old Jul 3, 2022 | 03:14 PM
75royal88's Avatar
1971 toronado 455
engine boggs down at wot , diesels 1/2 the time at shutdown
and if left undriven for a few days ,she wont start unless gas is poured into carb, then it runs fine.
changed a dirty fuel filter did not fix the issue. otherwise runs and drives fine with lots of power.
any suggestions?
Old Jul 3, 2022 | 03:31 PM
Sugar Bear's Avatar
Fuel pump failing, bad rubber hose at fuel pump and/or tank allowing air to get pulled in instead of fuel, clogged sock in tank? Does it bog on a full tank of gas or only when it gets low? Bogging on a low tank only would indicate a clogged sock. If the fuel filter was filthy the inside of the carb may be dirty.
Can you hear the secondaries on the carb opening?
Good luck!!!
snail
Jan 2, 2022 01:00 PM
montvaleplace
Feb 1, 2016 04:12 PM
montvaleplace
Sep 1, 2015 08:02 PM
BeenThere
Aug 31, 2014 07:01 AM
Miniucco
Mar 9, 2010 08:31 AM
