1971 455 w-30 camshaft help
Old Nov 30, 2025 | 04:20 AM
FLORIDA1972blaze's Avatar
I’m rebuilding a 1971 olds 455 ( Flint Michigan replacement block stamped) looking to change the camshaft to what was in a 1971 W-30 engine - need lift and duration numbers to order the correct cam - upgrading to roller lifters - AUTOMATIC TRANSMISSION
Old Nov 30, 2025 | 04:27 AM
joesw31's Avatar
In 1971 the 442 w30 used two different camshafts. One for auto and one for stick shift. Which specifications are you looking for?
Old Nov 30, 2025 | 04:31 AM
[QUOTE=joesw31;1660448]In 1971 the 442 w30 used two different camshafts. One for auto and one for stick shift. Which specifications are you looking for? Automatic transmission
Old Nov 30, 2025 | 06:19 AM
The 1971 W30 motors with automatic used two different cams.
Non-A/C cars used P/N 409691, 286/287 deg duration, 61 deg overlap, .474/.472 lift.
A/C cars used P/N 400165, 285/287 deg duration, 57 deg overlap, .472/.472 lift. Note that this is the same cam used in the 1969 H/O and in all 1970 442s (incl W30s) with automatic.
Old Nov 30, 2025 | 06:30 AM
[QUOTE=joe_padavano;1660460]The 1971 W30 motors with automatic used two different cams.
Greatly appreciated save me from going down the wrong path in building this motor !!!!
Old Nov 30, 2025 | 09:54 AM
Just to be clear, for 1971 there were THREE different "W30" cams, one for MT, one for AT with A/C, and one for AT without A/C.
Old Nov 30, 2025 | 03:03 PM
JerryW's Avatar
so are you going to have a cam made with similar specs to the W30? Of you are adding roller lifters, that means new cam, why not something more custom?
jerry
Old Nov 30, 2025 | 03:08 PM
I am posting this image (below) strictly as a 1971 OEM Oldsmobile supplemental image (document) to information which has already been accurately described/presented (above). It's a lousy image, yet it does depict the OEM cam grind, valve timing & color code for each cam (which is groovy).
Additionally, I am posting (as an attachment) information I have pursuant to assisting the OP w/ the engine build i.e. part #s, etc. (which may be beneficial). I think I stole this information from another CO member? Probably, yet it is good information & the purpose of this site is to share information.
File Type: pdf
JLawrence
Dec 17, 2024 06:58 AM
Drbigblock
Sep 2, 2024 08:05 PM
Falkon
Feb 22, 2023 11:38 PM
fishman
Dec 18, 2017 12:23 PM
alek72us
Aug 1, 2011 02:23 PM
