1970 Vista Coolant system
Old Oct 6, 2017 | 04:40 PM
bennie442s's Avatar
Currently building my 70 Vista Cruiser. My cooling system is not cooperating. I'll start with the basics:
-455 fresh rebuild, Edelbrock, aluminum heads, Accel DFI multi port fuel injection
-new spectra radiator, dual electric fans (pulling), new not rebuilt water pump
-upon starting up the car quickly climbs to 220; I shut the car down.
-upper radiator hose is not warm, does not feel like much coolant in the hose
-my first thought was air in the system
-with engine cool, filled radiator full, left radiator cap off
-car starts, see a few bubbles blurb...then at 210 coolant begins gushing out the radiator
-then removed thermostat
-added a sealed funnel for added capacity
-same things happens at 210 the coolant begins gushing out the top of the radiator
Do I have a brand new plugged radiator? Do I have a new water pump that is not working?
Thanks for your thoughts.
-ben
Old Oct 6, 2017 | 05:00 PM
VC455's Avatar
Barely Registered
With the thermostat removed and the coolant level below the filler neck, you should see circulation as soon as you start the car.
Old Oct 6, 2017 | 07:26 PM
If the temp moves very fast when you first start it up and then fluctuates wildly, there is air in the block.
Old Oct 6, 2017 | 08:50 PM
bennie442s's Avatar
Nothing erratic about the temperatures. Temp steadly rises with radiator cap on and off. I turn car off at 220.
Coolant bubbles over funnel at 210.
-ben
Old Oct 6, 2017 | 10:59 PM
As said, coolant should circulate immediately.
Do you see the coolant moving? We need an answer to this question before going any further.
Old Oct 7, 2017 | 02:01 PM
bennie442s's Avatar
Coolant is moving...out the filler kneck. Lower radiator hose is getting warm and becoming pressurized. Upper radiator hose is not getting warm and is not pressurizing.
Thanks,
-ben
Old Oct 7, 2017 | 02:22 PM
It sure sounds like something is plugged.
Old Oct 11, 2017 | 04:37 AM
I had a 70's Olds 350 back in the 80's that had a radiator leak. I took the radiator to a local radiator shop and he soldered off a couple rows. He gave me back the radiator and said to use a 7 lb cap because the rad was in Iffy shape. I found that the car would overflow out the overflow tube because 7lbs wasn't enough pressure. When I put back on the 15 lb cap all was well and drove the car until I sold it. My point is I learned you need pressure in the cooling system and maybe that's all your problem is....??
Old Oct 11, 2017 | 06:15 AM
He has a temp issue not a pressure issue. It could be many things but the radiator cap is not one of them.
tdhill01
Sep 15, 2016 04:01 PM
SeanMiller063
Aug 30, 2016 11:05 AM
GAOldsman
Aug 3, 2015 12:30 PM
ctrain22
Sep 16, 2009 08:54 PM
dar83501
Oct 24, 2007 05:21 PM
