1968 400 Not running on cyls 5 and 8
Old Jan 18, 2014 | 09:03 AM
TwilightBlue455's Avatar
Hi Everyone,
I have a question. A friends '68 400 is not running on cylinders 5 and 8. They both have spark and compression. They share an intake manifold runner. I have seen other engines with the two cylinders sharing a runner where one cylinder has an issue not allowing the other one to run. That runner has the vacuum port to the brake booster so I though it may have been a vacuum leak at the booster. I blocked off the hose to the booster and still 5&8 do not run. Plugs are not wet, has spark and 165psi compression. Any ideas??
Thanks for any help.
Old Jan 18, 2014 | 03:34 PM
stan 65 cutlass's Avatar
im thinkin flat cam lobes? but you have compression eh?
Old Jan 18, 2014 | 04:35 PM
Octania's Avatar
Spark, compression, and fuel, but won't fire?
That leaves timing, as in they have their wires swapped maybe?
Or, insufficient breathing due to the flat cam lobe...
GEARMAN69
Aug 10, 2022 05:39 AM
Mr_Ada
Oct 24, 2014 11:58 AM
rcktdoc
Mar 22, 2014 04:34 PM
Carl, uk
Mar 13, 2014 05:43 AM
68 Cutlass S
Aug 20, 2008 01:48 PM
