1968 400 Not running on cyls 5 and 8
Hi Everyone,
I have a question. A friends '68 400 is not running on cylinders 5 and 8. They both have spark and compression. They share an intake manifold runner. I have seen other engines with the two cylinders sharing a runner where one cylinder has an issue not allowing the other one to run. That runner has the vacuum port to the brake booster so I though it may have been a vacuum leak at the booster. I blocked off the hose to the booster and still 5&8 do not run. Plugs are not wet, has spark and 165psi compression. Any ideas??
Thanks for any help.
Carl, uk
Mar 13, 2014 05:43 AM
