1965 Olds 400 Build
Old Feb 9, 2024 | 06:54 AM
69Chrgr's Avatar
1965 Olds 400 Build
Hello Olds Friends
I finished up the 455 for Joe's 1970 442 convertible last year. It turned out FABULOUS! It was a close to 0 deck with C heads and factory intake and exhaust manifolds, forged pistons, mildly massaged cylinder heads retaining the 2.08 intakes and with a custom flat tappet cam provided by Cutlass EFI here on the website. Mark nailed the cam spot on and the customer and myself were more than pleased. If anyone wants pics of Joe's car let me know. I don't think he will mind. It's the nicest all stock and never restored 442 vert I have ever seen.
Now onto the next project. I will be starting another Olds build with a little more aggressiveness in mind. This is for a 1965 Olds 442 4-speed car. It will be an early 400 (large bore short stroke) with a Torker intake and should have the pistons close to 0 deck topped with a set of Speedmaster or Edelbrock heads. However, I need a source to find the early 400 camshaft (different valve angle) or cam core. If anyone knows where I can find some of those cams I would certainly appreciate it.
Best Regards,
Darren
Old Feb 9, 2024 | 10:07 AM
kjr442's Avatar
Kjr442
Convertible 442
Darren, that convertible is a nice car and you made it very wicked, but stock appearing.
I can’t wait till you get on the 65 400.
Old Feb 9, 2024 | 11:12 AM
69Chrgr's Avatar
Thank you Kevin!
Old Feb 9, 2024 | 04:45 PM
cutlassefi's Avatar
Hey Darren,
Ditch the Torker. And as discussed we’ll figure out the next cam choice.
Old Feb 9, 2024 | 05:46 PM
BillK's Avatar
Best Regards,
Darren
Erson had some 45 degree cores about a year ago anyway. They did one for me for a 425. I can check with them on Monday. I am pretty sure Mark uses their cams also ?
Old Feb 10, 2024 | 05:41 AM
cutlassefi's Avatar
Yes I do. But they haven’t had any Olds cores in awhile.
And flat tappet cores are the same, no matter if it’s 39 or 45*. Rollers can differ however.
Old Feb 12, 2024 | 06:03 AM
BillK's Avatar
Good to know. Learn something every day
Old Feb 12, 2024 | 06:07 AM
BillK's Avatar
Darren,
You might want to get in touch with Camcraft. They specialize in oddball stuff and have helped me out in the past.
https://www.camcraftcams.com/
Otherwise you might just have to get on the phone and start calling around to see if you can find someone with cores.
69Chrgr
Dec 1, 2021 07:50 AM
chrisneu68olds
Dec 30, 2011 10:17 AM
phildaville
Apr 4, 2011 03:37 PM
68442CONVERTCO
Sep 19, 2010 10:41 AM
Redog
May 4, 2009 12:06 AM
