1965 BBO passenger side Alt Bracket?
Old May 26, 2019 | 07:48 AM
jmos4's Avatar
Hi,
Was looking for a pictures of a passenger side alternator brackets, I have a set from a 65 330, but it's an early car and don't see how the upper will bolt on a BBO I am considering replacing with.
Thanks in advance, regards,
Old May 27, 2019 | 11:20 AM
MuchNeededAdvice's Avatar
Originally Posted by jmos4
Hi,
I have these photos from a ‘66 BBO. Don’t know it it will help.
Old May 27, 2019 | 03:45 PM
jmos4's Avatar
Hi,
Thanks that helps as my 65 has the 64 style brackets, anyone know what is different between 65 and 66-72?
Regards,
Old May 27, 2019 | 09:07 PM
VinMichael's Avatar
The 1964 330 upper alternator bracket needs to be modified to bolt on to a BBO. It’s too short for the mounting hole to line up with the block. I fixed this by welding an ear with a 3/8” hole in it from another alternator bracket to add length
Old May 27, 2019 | 09:23 PM
Gerald Nickels's Avatar
All venders sell the alt kit for big and small block. And on EBAY too.
Old May 29, 2019 | 06:40 PM
oldolds88's Avatar
bb and sb are different brackets,bb has an x on it
Old May 30, 2019 | 09:04 AM
brownbomber77's Avatar
I've got a set if you need it. Been blasted and painted with Rustoleum semi gloss black.
Old May 30, 2019 | 09:37 AM
jmos4's Avatar
PM sent
Old May 31, 2019 | 09:38 AM
According to this thread, you should be alright...
https://classicoldsmobile.com/forums...ets-bbo-39093/
OK, here's the scoop:
1964 SBO brackets are one-year only and will only fit an SBO (because the BBO didn't exist in 1964).
1965-67 brackets fit both SBO and BBO, but are unique to the 64-67 cars
1968-(about) 1977 brackets fit both SBO and BBO
1977-up brackets are SBO-only (since BBO production stopped after 1976). These brackets can be pretty easily modified to fit the BBO, however.
Note that the F-body SBO brackets are unique to the F-body cars.
--Joe Padavano
Old May 31, 2019 | 06:08 PM
jmos4's Avatar
Hi,
Thanks for the breakdown, but still curious why most re-pop suppliers and others say 66 up.
What does a 65 BBO bracket look like is there a difference?
I looked on 442bro and didn't see any mention of a 65 brackets any different
Regards,
Old Jul 21, 2019 | 11:21 AM
jmos4's Avatar
Fyi all,
Also 64 and early 65 sbo lower bracket is the same
Regards,
Old Jul 21, 2019 | 01:12 PM
The 66-up brackets will work on a 65, but they won't be optically correct.
66-3X2 442
Feb 25, 2018 07:39 PM
ReallyWildStuff
Jul 20, 2017 06:45 PM
jRoofgunner
May 29, 2017 07:42 AM
72 Olds Project
Feb 22, 2012 08:45 AM
jrmorte
Nov 24, 2009 07:17 PM
