1965 AC Fuel Pump - Are rebuild kits obsolete??
Old Mar 14, 2023 | 04:18 PM
Oldster65's Avatar
I am not able to find a rebuild kit for the fuel pump in my 1965 Delta 88 with the 425 (no Air Conditioning). It's an AC brand 6440030 (pictured). It seems there are kits available for earlier AC and Carter pumps, and later...but no luck for this year! Are they unusual for some reason?
Since I'm rebuilding everything possible on this survivor to keep it 100% original, I want to rebuild and keep this one. It leaks from the upper diaphragm where the top is bolted together, but the diaphragms are (kinda) ok. I may try to just re-seal it, but I don't expect it will survive ethanol very long, so I want to do it properly with new rebuilt parts. I did buy a new Carter unit to get me by for now.
Any ideas on where I might find a rebuild kit (and of good quality)? NOS likely won't work because I want ethanol-proof parts.
Original AC 6440030 mechanical fuel pump (no A/C) -1965 Delta 88 425ci
Old Mar 14, 2023 | 06:18 PM
Try this guy.
http://www.classicpreservation.com/fuelpumpkits.html
Old Mar 14, 2023 | 06:26 PM
tnswt's Avatar
'70 4-Speed W Machine
Here's another source.
https://cowboyjohnsautoparts.com/
Old Mar 17, 2023 | 12:41 PM
Oldster65's Avatar
Thank you both for these referrals. These are exactly the kind of business I want to leverage and we need to keep alive!
I stuck in the carter for the time-being. But will get a kit from one of these folks and get the og pump back in there asap.
New replacement until the old gets rebuilt.
Old Mar 29, 2023 | 05:51 PM
Oldster65's Avatar
Does this pin press out?
I have a rebuild kit on the way from Cowboy Johns.
Question, I'm trying to remove the lever arm, and I thought I knew just by looking that this pin would come out with a drift punch (or press) - like most of these type of pumps. I am very familiar removing roll pins and pressed in pins, etc. but the first smack felt dead solid, the pin didn't budge, and another hit seemed likely to just mash the end of the pin. I don't want to destroy this pump or its parts.
Before I try using my press, does anyone know - with 100% certainty - that this pin is pressed in in these "65 AC model fuel pumps? (I checked for circlips on the inner part of the lever/pin but there are none, nor are there any on the outside.)
Am I missing anything...or am I just not using enough force?
Old Mar 29, 2023 | 06:19 PM
tnswt's Avatar
Try tapping the pin from the other end to see if that produces movement?
https://www.hemmings.com/stories/art...mp-restoration
Old Mar 31, 2023 | 03:03 PM
CANADIANOLDS's Avatar
I think I have a brand new pump like that ?
if you are interested, let me know…I’ll send pics. It’s the original Zinc? not aluminum
Old Apr 3, 2023 | 08:57 AM
Oldster65's Avatar
I will, asap. (Project delays have intervened, as typical). Thank you.
F85_1965
Aug 30, 2022 07:01 AM
Mark57
Sep 23, 2014 02:37 PM
Boiler_81
Sep 3, 2013 05:43 AM
67 Cutlass Freak
Feb 1, 2012 02:58 PM
Captain_Fish
Mar 2, 2011 04:30 PM
