1964 F85 425 swap
Old November 9th, 2019 | 07:41 PM
  #41
Cmpeirce123's Avatar
Cam and lifters look good. Those were replaced less than 10k ago.
Old November 10th, 2019 | 07:28 AM
  #42
64Rocket's Avatar
Don’t mix them up. The lifters have to stay with the lobe they came off of.
It should be a .921 lifter, 39* cam.
why was it taken out and sold if only 10K miles?
Old November 10th, 2019 | 07:37 AM
  #43
I screwed up there. I’m not sure the Order they came out. Do I need to replace lifters, cam, and springs now? The motor was pulled for an LS swap. It’s the 45 degree cam also.
Old November 10th, 2019 | 08:33 AM
  #44
64Rocket's Avatar
In my opinion yes on the lifters for sure. If you did not keep them in
order. What cam is in it. Should have markings on one end or the other. If you wanting a new cam, Lunati has a thumper style cam. Has a lot of thump in them.
does it have the big lifter, (.921) ?
Old November 10th, 2019 | 10:17 AM
  #45
Originally Posted by 64Rocket
In my yes on the lifters for sure. If you did not keep them in
Its a Howard’s cam on it. I don’t know all the numbers off the top of my head but I have the paper work for it at home.
Old November 10th, 2019 | 11:53 AM
  #46
64Rocket's Avatar
Post the paper work. That will say a lot about the cam.
Gene
Old November 10th, 2019 | 03:05 PM
  #47
Oldsmaniac's Avatar
A 65 425 A block will Not have 921 lifters... and for sure 45 degree cm angle
Old November 10th, 2019 | 04:37 PM
  #48
Gene
Here’s cam info.
Old November 10th, 2019 | 04:42 PM
  #49
64Rocket's Avatar
The general rule of thumb is big lifters (.921) 39 cam
small lifters (.842) 45 cam
and yes there are exceptions as in a 67 block. And others I’m sure.
Gene
Old November 10th, 2019 | 04:48 PM
  #50
64Rocket's Avatar
That is a nice cam, would make a great street cam.
with the .842 lifters, should be easy to get new ones.
what intake are you using?
what rear end ratio are using ?
what trans do you planing to use?
Old November 10th, 2019 | 04:59 PM
  #51
Edelbrock performer intake, rearend is stock not sure the gear ratio Ive been told to swap the stock gears out tho so will do that also this winter, and I have a TH400 to swap in with this motor. What gear ratio should I go with? This is going to be a street car stop light to stop light.
Old November 10th, 2019 | 05:42 PM
  #52
64Rocket's Avatar
Rear gears
I like the 3.23's a nice ratio, will work on the stop to stop light run and ok on the freeway.
3.08 is a good one also. The numerical higher ratio makes for lesser ability to drive the freeway.
Old November 12th, 2019 | 04:05 AM
  #53
cutlassefi's Avatar
That’s the same generic cam that everyone sells, Edelbrock, Lunati and so on. They have a tendency to be a bit lazy.
Old November 12th, 2019 | 10:25 PM
  #54
svnt442's Avatar
Originally Posted by Cmpeirce123
Here’s cam info.
They mixed something up when printing that cam card out because they have the intake and exhaust lifts crossed with each other between gross and net lift.
.311 x 1.6 = .4976 (.498)
.296 x 1.6 = .4736 (.474)
Old November 15th, 2019 | 10:32 AM
  #55
I am putting new rod and main bearings in. The ones that came out are .001 my parts store says they can’t order any in that size. Can I use standard sized bearings? Or will my crank need turned and go up to .010 bearings?
Old November 15th, 2019 | 11:05 AM
  #56
Oldsmaniac's Avatar
If crank is out have it turned, this will eliminate guessing, it would be wise to have gig end of rods checked as well... Use plastigage when assembling main and rod bearings.
Old November 15th, 2019 | 12:49 PM
  #57
VinMichael's Avatar
I’d mike the crank to see if you can use STD bearings. A little loose isn’t a a bad thing. Definitely check the big ends of those rods to see if out of round.
Old November 15th, 2019 | 05:03 PM
  #58
Sugar Bear's Avatar
^^^This^^^
Old November 15th, 2019 | 08:17 PM
  #59
64Rocket's Avatar
Be sure to clean the block.
I would have the crank turned. 10/10 would be perfect.
I say use a "Cloyes true roller timing set.
Use the Ford 460 rear main rubber seal
Have the block deck machine for straightness
Have the machine shop measure the piston to cyl wall clearance.
Have the big end of the connecting rods size check
Just my opinion
Gene
Old November 16th, 2019 | 07:21 PM
  #60
I ended up finding .001 bearings through a parts surplus store online. I just got the heads back. Got the valves cleaned, new exhaust guides, and seals. The previous owner didn’t have any valve seals in the heads and the exhaust guides were shot. Pretty sure that had to be the ticking noise. Because everything else looked good through the tear down.
Old December 9th, 2019 | 02:57 PM
  #61
I have the motor almost put back together. Just have to put valve covers on, intake, distributer etc. this motor came with an edelbrock 1406 600cfm carb. What would be a better carb for this motor? 600cfm seems small for this motor. I have an edlebrock performer intake on it and also an offenhauser dual 4 barrel laying in my shop that I got from my step dads old cutlass back in the day. But I’ll pry stick with the Edelbrock for now.
Old December 9th, 2019 | 03:08 PM
  #62
VinMichael's Avatar
Since you already have it, might be wise to buy a tuning kit and see what you can get out of it. I’ve had one of those carbs for years on small blocks. It’s a good carb.
Old December 9th, 2019 | 04:28 PM
  #63
ok sounds good. I have a Holley 600 on my 330. Didn’t know if a 600cfm would be big enough for a big block tho.
Old December 9th, 2019 | 06:39 PM
  #64
VinMichael's Avatar
Me neither. But it would be cool to see it done.
Metering rods and jets are easy enough to change on those carbs.
A tuning kit and a A/F ratio gauge will get the best tune. And take the carb to its limits.
Old December 11th, 2019 | 05:06 AM
  #65
olds 307 and 403's Avatar
Out of Line, Everytime😉
Dump the Edelbrock carb, way too small and many have issues with them. I say a 750 Street Demon or a Quickfuel Slayer 750 for a carb. Any carb will need tuned to your motor, why leave a bunch of power on the table?
Old December 15th, 2019 | 09:28 PM
  #66
VinMichael's Avatar
For the right application why wouldn’t that carb run sweet? How would it compare to a stock two barrel.
Old February 11th, 2020 | 03:59 PM
  #67
Have started swapping the motor in. Waiting on a new radiator the one I got sent was two inches to high. The headers have also been a pain in the ***. Have put quite a few dents in them already. I believe these are cheap flowtech tho. They came with the engine. Will have to look into the hooker headers.
Old March 29th, 2020 | 08:42 PM
  #68
64Rocket's Avatar
Sooooo, whats the latest word ?
Is it running yet?
Need update pic's also.
Gene
Old March 29th, 2020 | 09:59 PM
  #69
Yup got it running. Need to get a bigger carb still. The motor runs great! I am very happy with it so far. I still have the 2 speed in it. Have to get the th400 swapped in still. I went with 3in exhaust with dynomax ultra flows. Have to get a smaller air cleaner as the current one doesn’t clear the hood. Won’t let me upload any videos. I’ll have to look into that.
Old March 30th, 2020 | 05:29 AM
  #70
Looks awesome. Did you change carbs to a Holley?
Old March 30th, 2020 | 06:12 AM
  #71
Yeah I had a new holly I had on the 330 I used. The edelbrock was also a 600. Think I’m going to get a holly 750 double pumper.
Old March 30th, 2020 | 06:22 AM
  #72
The reason I asked is because this air cleaner may help keeping everything under a flat hood if your still having issues.
https://www.ss396.com/chevelle/ATE-3...hevelle&year=0
Old March 30th, 2020 | 08:25 AM
  #73
64Rocket's Avatar
For me it looks like the air cleaner stud is to long and that will keep you from closing the hood.
Looks good. Even with the 2 speed trans, probably runs better already.
Old March 30th, 2020 | 09:41 AM
  #74
Yup I used a shorter stud. Hood closes but the top of the air cleaner hits one of the hood braces. So the back sticks up a little bit and doesn’t close flush. Does run a lot better. Night and day difference. I haven’t really gotten on it much as I don’t want to blow the 2 speed up.
Old June 29th, 2022 | 08:22 AM
  #75
65cutlassnorth's Avatar
I’ve found a 425 olds for sale. I currently have the original 330 in the car with the 2 speed transmission. The car runs and drives right now but I’ve been wanting more power and the 330 could really use freshened up. I found a 425 locally for $300 so I figured maybe a big block would be a better choice to swap in this winter than messing with the 330.
Il still keep the 330 as it is the original engine. My question is should I swap a 425 in? I haven’t found any 455’s locally. What is needed to swap a big block into my car. Just big block mounts? I see everyone talks about how narrow the frame is in the 64-67’s.
I was planning on pulling the 330 and getting the heads cleaned up, new cam etc, and swapping either a th350 or 400 in along with new rear ended gears. Is there a better cam choice for the 425 and would this be a good swap? I’m assuming the 425 will need rebuilt as it has been sitting since the late 80’s. It was rebuilt at that time the owner says.
My goal was to have the car sounding mean and being able to roast the tires when I wanted too as of right now that’s not the case. Which is understandable for sitting for 25 years. My car had been sitting since the 90’s so I just did a tune up to get it running and drivable for the summer while I worked on the interior before winter.
Beautiful!!!
67Rocket
February 9th, 2017 05:45 PM
67cutlass67GS
October 27th, 2014 05:22 PM
Old Olds Fan
October 2nd, 2013 05:19 AM
nonhog
March 12th, 2012 07:52 PM
nickd
April 6th, 2009 10:01 AM
Quick Reply: 1964 F85 425 swap
